just bought a 2000 major motor problems need help - JeepForum.com
post #1 of 21 Old 01-23-2011, 08:27 PM Thread Starter
chrisdzwle
I just bought a 2000 sport with 4.0 and 127000 miles, ran great for about a week. i changed the oil and put in lucas oil stabilizer. then i got a very loud knock. brought it to my friends shop and he said i have a spun rod bearing and cracked cylinder head. what do you guys think i should do? thanks
chrisdzwle is offline
post #2 of 21 Old 01-23-2011, 08:30 PM
Bama1987
4.0 or 2.5?
Bama1987 is offline
post #3 of 21 Old 01-23-2011, 08:31 PM Thread Starter
chrisdzwle
4.0
post #4 of 21 Old 01-23-2011, 08:33 PM
Bama1987
Sry didn't see sport up there buy a new head and fix the rod replace them all while ur at it. My buddy got a complete 4.0 fo 400 replace the whole thing if u can find a deal/ good junkyard find
Bama1987 is offline
post #5 of 21 Old 01-23-2011, 08:33 PM
gixxerphil
stroker
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline
post #6 of 21 Old 01-23-2011, 08:34 PM
Bama1987
Or trade with me I'll pull it out and put a 302ford in it. Haha
Bama1987 is offline
post #7 of 21 Old 01-23-2011, 08:36 PM
Bama1987
Originally Posted by gixxerphil_ View Post
stroker
Or that. But idk hes an auburn fan
Bama1987 is offline
post #8 of 21 Old 01-23-2011, 08:40 PM Thread Starter
chrisdzwle
if i decide to fix it myself what year heads can i use on my 00 block?
post #9 of 21 Old 01-23-2011, 08:50 PM
Bama1987
Not 100% sure but I would imagine 97-02 i think. But it would probly be cheaper to pull the whole motor now that I think about it especially if you've never rebuilt an engine. getting a used head it will need to be machined 80-120$ plus gasket 50-100$ plus your rods if it were me and I wanted to keep the 4.0 I'd replace the whole engine. There are alot of grand Cherokees with 4.0s in our local junkyard.
Bama1987 is offline
post #10 of 21 Old 01-23-2011, 08:50 PM
gixxerphil
War Damn Eagle
post #11 of 21 Old 01-23-2011, 08:51 PM
BomberJeep
2011 WK
I would shop around for a new head. IIRC I saw some in q-tec for about 450ish with all the goods installed on them. All you would basically have to do is pop the old head and put the new one on. No muss not fuss.
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #12 of 21 Old 01-23-2011, 09:22 PM
wushaw
Rockin jeep
wushaw's Avatar
Don't mess with it, just rebuild it or get a rebuilt motor or a "KNOWN" good engine. 127k is nothing for mileage the PO must have overheated it and the damage was done.
wushaw is offline
post #13 of 21 Old 01-23-2011, 10:28 PM
2ACR
That's Right I Support
2ACR's Avatar
Get a new engine and then learn how to rebuild the spare. That's my plan. Jeeps just aren't fun if you aren't learning something.
I miss Alabama. Oklahoma people just don't know good football. BTW ROLL TIDE
Originally Posted by jr03 View Post
And when you can't find the wrench your holding in your hand, it's time for a break:rofl:
Jeep Jedi in Training.
2ACR is offline
post #14 of 21 Old 01-23-2011, 10:41 PM
baldeagle1
sounds familar. I bought a 2000 TJ 4.0. Drove for 6 mths then piston hat broke off. I would do what was metioned. Buy a used 4.0 and rebuild yours.
baldeagle1 is offline
post #15 of 21 Old 01-23-2011, 11:23 PM
witness
2000 4.0L have the 0331 head casting which is very well known for cracking. Mine went the other day, just turned 80k miles. I think my PO thought it was a head gasket and put a bunch of sealer in the coolant and patched it up instead of fixing it correctly.
Cracked head isn't a huge deal, you can get a head from Alabama Cylinder head for less than $500 shipped to your door, torque it down and hit the road. If the rod bearing truly is bad, then you need a rebuild. I think a lot of people jump to the bad rod bearing a little too quickly. Do some research, make sure you got the correct diagnosis before making any decisions. Motor swaps are a pain in the ***, then again so is a rebuild.
witness is offline
Bought my 3rd Jeep last night - 2.5 liter with major oil leak Area.3.Fiftyone YJ Wrangler Technical Forum 15 04-17-2010 03:50 PM
just bought a 97 tj w/33" toyos, major vibration 35-50 rugerdog TJ Wrangler Technical Forum 7 07-05-2009 04:49 PM
major problems plz help keffreg JK Wrangler Technical Forum 3 06-27-2009 10:29 PM
major fuel problem with modded motor durph TJ Wrangler Technical Forum 15 01-21-2009 08:49 AM
Help Major Tj Problems thekrutchmaster TJ Wrangler Technical Forum 4 12-08-2004 09:22 PM
