Just bought an 05 Wrangler and having a few major issues need help quick - JeepForum.com
post #1 of 22 Old 06-12-2011, 12:02 AM Thread Starter
evanmullins1986
I purchased a 2005 Jeep Wrangler with 85,000 miles on it about a month ago. Thinking it would be a fun vehicle to own and drive well it has quickly became a nightmare !!
I had only had it 3 days and the plastic position clip that secures the linkage to the gear selector broke, then yesterday I had to have a water pump replaced because it was leaking (when NOT under preasure) and now I have another issue and dont know what is going on.
For a week or so I noticed it was kind of missing and also had a squeak coming from the rear drivers side as the brake peddle was applied and let out ( not al the time but sometimes) NOW starting today it has an even rougher idle the rpms fall suddenly from the normal idle range to practically nothing then rise to about 1200 then back to normal then down again. ( this also is not something that is continues) The rough idle however is almost constant in any gear. It seems to smooth out to almost normal when the A/C compresor is engaged but will almost stall when it is turned off but recovers. Also there seems to be a very slight hesitation when the gas peddle is applied.
I have been told this could be several things but would like to hear some opinions. I checked for a vac leak using carb cleaner on the engine but it doesnt seem to have one. I really need this Jeep running properly ASAP so all advice is desperatley needed!!
Also another issue that is a real pain is that my two center vents dont blow out any air on A/C, heat, fan, doesn't matter. The other vents all work properly so if anyone can help there I thank you also.
evanmullins1986 is offline
post #2 of 22 Old 06-12-2011, 04:50 AM
4banged
What engine do you have? I recently replaced the waterpump on my 03 wrangler 2.4l engine when I did the timing belt...the 1st time I did it I was off a tooth on the timing belt and it ran but I knew it wasn't right (idle was weird and not as much power) so I did it again and got it perfect - runs great now.
As for the ac vents...mine had that issue when I test drove it at the dealer I bought it from and he took care of it ...said it was a fuse but I'm not sure where its located.
Good luck...hope you have a good set of tools...these things like to be worked on. Highly recommend a fridge with beer in the garage to keep you hydrated ;-)
4banged is offline
post #3 of 22 Old 06-12-2011, 05:52 AM
rockwallchamp09
ever heard of the lemon law i think whomever sold it to you broke said law was it from dealership by any chance id would send it back unless you did this the first day you got it
rockwallchamp09 is offline
post #4 of 22 Old 06-12-2011, 08:38 AM
Garza
Try this first for your idle problem.
http://www.jeepforum.com/forum/f9/lj.../#post11584239
RG
Garza is offline
post #5 of 22 Old 06-12-2011, 10:15 AM Thread Starter
evanmullins1986
The Jeep is the 4.0 L. I did buy it from a used car dealer
post #6 of 22 Old 06-12-2011, 11:48 AM
Smeg
Lemon law usually pertains to new cars, not 7 year old cars. Good luck with that.
Tennessee Lemon Law 55-24-202. Nonconforming vehicles - Reports - Repairs.
If a new motor vehicle does not conform to all applicable express warranties and the consumer reports the nonconformity, defect or condition to the manufacturer, its agent or its authorized dealer during the term of protection, the manufacturer, its agent or its authorized dealer shall correct the nonconformity, defect or condition at no charge to the consumer, notwithstanding the fact that such repairs are made after the expiration of such term. Any corrections or attempted corrections undertaken by an authorized dealer under the provisions of this section shall be treated as warranty work and billed by the dealer to the manufacturer in the same manner as other work under warranty is billed.
History
http://www.lemonlawamerica.com/Tenne...w-Statutes.htm
Also, most dealers have a 30-90 warranty, might see what they will honor, unless, it was marked "As is"
'06 TJ Yellow nothing special
'15 WK2 Limited Deep Cherry Red Wrecked
'12 WK2 Laredo Black Wrecked
Smeg is offline
post #7 of 22 Old 06-12-2011, 12:24 PM
Richd1963
Richd1963's Avatar
Allot of good info here. I would definitely be checking everything on that jeep since taking ownership. Used car lots usually just do the bare minimum to get a car sold. I would start by inspecting all the spark plug wires, air filter spark plugs. I am not sure how mechanically inclined yo are, but the Throttle body cleaning maybe something you would want to inspect and consider.
Don't be too discouraged. It sounds like just a case of a little bad luck is all. Sometimes *hit happens coincidentally and you just hit it at that time. I bet if you get a few of these minor bugs worked out, you will be more than happy with your TJ. The brakes probably should get a good inspection too as well as all fluid levels in the differentials and transfer case. Have it gone through and if you don't have proof of any recent services, I would start having them done so you will have a benchmark for the future. I know it costs money, even if you can do it yourself. The materials are somewhat costly especially if you use the recommended ones, which I strongly recommend. But in the long run, I think you will be pleased, it will just be a little time before you get some peace of mind.
This is one of the draw backs with buying a previously owned vehicle from some one or place that will not fully warranty the vehicle for any reasonable length of time. Hence the brake light warranty and this usually results in the seller not taking that great of care of such vehicle. Whereas the dealer and new vehicles are well maintained and taken care of, because they really don't want you coming back, and since it is warranty work, they really don't make much money on the jobs, although the MFR reimburses the dealership for warranty repairs. Of course I am getting off track and am sorry, just needed to show difference in benefits between buying used vs. NEW.
Save up and do the most important services first and so on. We all wish you luck and success.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #8 of 22 Old 06-12-2011, 01:54 PM
200xva
i went out mudding the other day and about a weak later the jeep started ideling crazy on start up alot like you what you described changed airfilter and runs like a champ. by looking at the air filter it didnt look that bad but for 13 dollars figured i would try it first. anyway just something else to look at.
200xva is offline
post #9 of 22 Old 06-12-2011, 04:14 PM Thread Starter
evanmullins1986
Thanks for all the great replies. The jeep doesn't seem to idle and hesitate all the time. It just kind of comes and goes. Take it does have a miss in it from needing plugs which I plan to change tomorrow but the bad rpm stumble just occurs on occasion. I put seafoam in the fuel so I am hoping that helps. I am also going to spray the throttle body out.
I am still trying to find the reason the vents don't work so any input on that is greatly needed ! I am having trouble locating the vacuum hoses and canister under the hood. Does anyone have a pic of this or a video of how to check them ? I am not much of a mechanic but I am tired of spending money on this thing so I appreciate your knowledge.
post #10 of 22 Old 06-12-2011, 05:31 PM
nmj48
the mode door actuators (directs air to your vents) are vacuum operated. the vacuum reservoir is located under the battery tray. on the drivers side of the intake ( kind of underneath it) there is a vacuum line that pops off sometimes. this line runs along the top of the firewall to the reservoir under the battery.
nmj48 is offline
post #11 of 22 Old 06-12-2011, 06:07 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
Look straight at your engine. You will see the air tube coming out of the throttle body quick is mounted to the intake manifold. On the right side of the I take manifold towards the middle the should be a vacuum line plugged in. If all you see is a nipple coming off the manifold find the line and plug it in. Then watch your idle balance out and you vents work properly.
I hope this fixes your problem
Recoil is offline
post #12 of 22 Old 06-12-2011, 06:50 PM Thread Starter
evanmullins1986
I am still having trouble locating the vacuum can. My battery is on the passenger side but I don't see the vac lines. Sorry I know dumb of me !
post #13 of 22 Old 06-12-2011, 08:32 PM
nmj48
remove the battery and the battery tray, the reservoir is underneath
http://www.jeep4x4center.com/jeep-service-manuals/Jeep_Wrangler_TJ/2003/Heating_and_Air_Conditioning.swf#toolbar=0
check out the link, its for 2003 but yours should be the same. vacuum reservor is on pg 31. the link also contains procedures to test it
nmj48 is offline
post #14 of 22 Old 06-12-2011, 09:02 PM
Richd1963
Richd1963's Avatar
I know on my 4.0 when the vacuum hose comes off the intake manifold, it renders the vent controls on my ac and heat in operable. I go out and re attach the hose and everything works fine. My hose is worn out and the rubber doesn't quite grab and hold like it used to. I used a super small zip Tye to restore some tightness to the hose and it hasn't come lose since. But anytime my controls go to crap, that's where I look. its just across and under the master cyl.
post #15 of 22 Old 06-12-2011, 09:13 PM
robncar
robncar's Avatar
Clean the IAC (I-dle A-ir C-ontroller) on the throttle body. On the '05 you'll need a T-20 torx driver, a small mirror will help you see the single torx screw, a tooth brush, and a large can of throttle body cleaner.
Don't get discouraged, once you get the little things sorted out you'll be fine.
Sent from my DROID2 using JeepForum
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
rough idle , rpm increase , stall issue , vents
just bought a 2000 major motor problems need help chrisdzwle TJ Wrangler Technical Forum 20 01-26-2011 08:09 PM
Just Bought Another Wrangler & Already Having Issues.. 97TJnSC TJ Wrangler Technical Forum 72 03-14-2010 12:52 PM
Any Major issues with the 2007 Wrangler JK ? 08JeepMan Wrangler General Discussion 2 07-09-2009 12:01 PM
just bought a 97 tj w/33" toyos, major vibration 35-50 rugerdog TJ Wrangler Technical Forum 7 07-05-2009 04:49 PM
Major issues with 2008 Wrangler Sahara? gregyoon JK Wrangler Technical Forum 8 03-30-2009 04:39 PM
