Junkyard Roof Rack - Page 15 - JeepForum.com
post #211 of 218 Old 01-13-2015, 04:54 PM
tcmault
Can you do some close ups of how it is mounted? Inside and out?
Originally Posted by Wagex View Post
i got one of these off ebay, made a couple aluminum cross bars to bolt it to the existing roof rails perfect length for a TJ. its the long version of a rage roof rack. people say it looks cheap but its strong enough i can grab ahold of the top rail and use that to pull myself up to the top of my jeep and stand/ walk around on top i think i paid just over a hundred for it.
Attachment 1763682 Attachment 1763690Attachment 1763706
2006 AEV Unlimited Rubicon. Silver. 6-speed. 255/85R16. OME ZJ/LJ. Nth TT. Alloy Shafts.
tcmault is offline
post #212 of 218 Old 01-13-2015, 07:23 PM
RubiDee
Originally Posted by Gamgan View Post
I want to do this but here in PR all the junkers want to sell me a 00-01 ford explorer rack for $100-150 all beat up and used.
Can this be done with another rack? Jeep cherokees look like they have a similar flat rail system and rack??
Yes, Cherokee rack width is perfect, just cut tracks to length with hacksaw and bolt down. Tracks are nice and flat and blend in with top nicely.
RubiDee is offline
post #213 of 218 Old 01-15-2015, 06:14 AM
Gamgan
Thats great to hear. Any idea what year I should be checking on the cherokees?
Gamgan is offline
post #214 of 218 Old 01-15-2015, 08:08 PM
RubiDee
Don't remember what year...mid 90's? I think they were the same for a long time
RubiDee is offline
post #215 of 218 Old 07-16-2015, 04:30 PM
badweatherbiker
snagged the roof rack off my daughters wrecked 2004 Mazda Tribute, lined up just fine but no pics or haven't used it yet
badweatherbiker is offline
post #216 of 218 Old 10-12-2016, 06:57 PM
RDaniel2405
RDaniel2405's Avatar
Just thought I would post a quick pic, I have only used my junk yard roof rack a few times. But today I picked up 6 8ft 2x4's and a 8ft 2x6.
OEF Veteran & owner of a 2006 TJ
Instagram @theorangejeep
Pirate 4x4 @theorangejeep
RDaniel2405 is offline
post #217 of 218 Old 02-05-2017, 10:33 PM
amgriswo
so true
amgriswo is offline
post #218 of 218 Old 02-19-2017, 10:07 AM
irnmadn88
I went to a Pull-n-Pay and found two roof racks from mid 90's XJ's. $24.48 each and now I have four crossmembers.
Could have pulled racks from later XJ's or even GC's.
Some GC's use the same rack rail as the mid 90's XJ's but they are spaced narrower so the cross bars are shorter.
I would have preferred the rails from a late 80's XJ but none were there. They are a different system and mount more flush than the ones I pulled.
So I need to narrow the cross bars a little so the rails are just outboard of the outer most ribs on the top and decide if I want the full length of the rail or shorten them one or two mounting holes. I chose the wider width because I may want to put in a sun roof.
From the rear:
From the front:
From the side:
A JF user pic of a sunroof. You can see where the rails being outboard of the outer ribs would be good if I keep the full length of the rail.
Colorado Jeep Club Member #667
irnmadn88 is offline
hardtop , lj , roof rack , tj
ski rack options spare tire or roof rack Therou TJ Wrangler Technical Forum 17 01-04-2010 12:02 PM
What is the better roof rack, Garvin Exp. Rack or Kargo Master Drew99 TJ Wrangler Technical Forum 6 03-17-2009 05:33 PM
Letís See Your Rack Ė Roof Rack Shopping Need IdeasÖ PLEASE czar97 TJ Wrangler Technical Forum 44 03-17-2009 01:26 PM
Junkyard roof rack for hardtop? ZonaWrangler YJ Wrangler Technical Forum 4 04-21-2008 11:31 PM
Alternatives to roof rack or hitch rack waterboarder JK Wrangler Technical Forum 17 02-10-2008 06:58 PM
