Junkyard Roof Rack - Page 14 - JeepForum.com
post #196 of 218 Old 07-21-2014, 12:47 AM
HighRoller02TJ
Originally Posted by horn34 View Post
A cordless drill/screwdriver with a normal size philips bit. Takes 5 minutes to unscrew. If you do it with a regular screwdriver, maybe 10 minutes.
sounds good thanks
HighRoller02TJ is offline
post #197 of 218 Old 07-21-2014, 06:35 AM
Jughead
2011 WK
So how much weight can the hardtop hold using these racks?
Jughead is offline
post #198 of 218 Old 07-21-2014, 06:01 PM
HighRoller02TJ
has anyone used a rack from a 2002 explorer xlt or one from this generation? just want to make sure it works. maybe we can get people listing what rack they used to help me and others also. thanks
post #199 of 218 Old 12-14-2014, 01:36 PM
toxikmo
Has anyone added more bracing to these , mine flexes abit more than I like. When I have my snowboard up top.
I was thinking about adding some just not sure if I should do it side to side or front to back
toxikmo is offline
post #200 of 218 Old 12-14-2014, 06:52 PM
RubiDee
I used a rack from a 90's XJ, shortened tracks by 10" and bolted thru top with fender washers on inside, been great for 2 yrs. Not sure about explorer rack but the years I've seen look pretty bulky compare to the XJ rack and crossmembers come off easily when not in use. I think others in the thread used Explorer racks.
RubiDee is offline
post #201 of 218 Old 12-14-2014, 06:55 PM
RubiDee
What flexes? Crossmember? Mine only flexes when I have more than 100 lbs (lumber, etc.) Not sure why a snowboard would make it flex, they are light.
RubiDee is offline
post #202 of 218 Old 12-14-2014, 07:20 PM
toxikmo
Mine flexes on the rails passanger back right bolt started leaking(silicone on all bolts) only after I have 2 board on the yakima fat cat 6 on the rack.
I can't upload a pic since file is too big and don't know how to compress ir on my phone.
My plan was to reinforce it on the inside. Just not sure if I should go from
driver side to passenger side.
Or
Front to back
Or...
Create a "U" for the front and one fore the rear but for that I'd have to find someone who can weld it up. Since I can't.
I Found some metal that would fit either way just have to cut it down and drill some holes paint and install.
So just not sure which way I should do it.
Mine is from a windstar.
toxikmo is offline
post #203 of 218 Old 12-15-2014, 11:39 AM
Wagex
when i bought my tj someone had already put the rails up there problem is they did not leave the cross bars lol i wish i had a clue what they took it off of so that i could find some cross bars, the universal ones are expensive and too long imo.
Wagex is offline
post #204 of 218 Old 12-15-2014, 12:09 PM
Yucca-man
Post some pics, maybe someone will recognize yours.
Yucca-man is offline
post #205 of 218 Old 12-23-2014, 01:39 PM
MFNKLJ06
Hard Top Roof Rack
So I'm pretty much sold on the roof rack, but I have a question.
Has anyone who has added a roof rack to their hard top, just it to lift the top off of the jeep with hoist?
As far as racks you can order, Garvin claims that you can with no issues with their rack. I emailed them and asked.
I have a top hoist of my design in the garage now, and I know it would need some reconfiguring, but I am curious if anyone has done it.
MFNKLJ06 is offline
post #206 of 218 Old 12-24-2014, 09:06 AM
Submariner
Submariner's Avatar
I put the same rack on my hard top but I have left off the cross bars to mount 1 1/4" Sq steel pipe that is 48" long on top to give plenty of room to haul my canoe. I have also made a carrier from two ATV racks from harbor freight to mount on top of the roof rack. I stood on top of the hard top loading stuff and there was no indication of undue stress to the hard top.
I also use a hand wench from Harbor freight to lift the top off with no indication of undue stress to the top. I used a side wind hand winch, cost $29 and used a couple of pulley wheels to facilitate the cable from the side of the shop to the rafters of the shop. works well. get the top off in 20 minutes by myself.
Submariner
Submariner is offline
post #207 of 218 Old 12-24-2014, 09:13 AM
Submariner
Submariner's Avatar
Originally Posted by jscherb View Post
Here's a little more on that idea...
Works out really well, and if you buy the HF racks on sale you can built it for maybe $75, shown below on an XJ rack on my LJ:
Here's a whole thread on the rack project, which also shows how to do Highlift jack mounts, front light mounts, and a spare tire mount for it: http://www.jeepforum.com/forum/f11/b...asket-1089244/
I use mine on the trail all the time, it's a great place to carry an extra spare and the jack, and in the photo below I've also got a roll-aboard size suitcase up there. You can just barely make it out in this photo, but there's also a bungee net on the rack to hold things like the suitcase in place; the net was less than $20 at Tractor Supply.
Better photo of the net when the rack was off the Jeep:
The only thing I would add to this is weld in a few extra inches to make it a little wider and longer. I did that with a 110 volt wire feed welder. worked so well my daughter "borrowed" it from me while she was home one weekend.
Submariner
post #208 of 218 Old 12-25-2014, 12:17 AM
Wagex
i got one of these off ebay, made a couple aluminum cross bars to bolt it to the existing roof rails perfect length for a TJ. its the long version of a rage roof rack. people say it looks cheap but its strong enough i can grab ahold of the top rail and use that to pull myself up to the top of my jeep and stand/ walk around on top i think i paid just over a hundred for it.
Size:  13.3 KB rack.jpgrack2.jpg
Wagex is offline
post #209 of 218 Old 01-13-2015, 06:55 AM
Gamgan
I want to do this but here in PR all the junkers want to sell me a 00-01 ford explorer rack for $100-150 all beat up and used.
Can this be done with another rack? Jeep cherokees look like they have a similar flat rail system and rack??
Gamgan is offline
post #210 of 218 Old 01-13-2015, 07:00 AM
Gamgan
Nissan pathfinder rack is flat too. Im curious if the width of the crossmembers on the cherokee or pathfinder will work though.
Gamgan is offline
hardtop , lj , roof rack , tj
ski rack options spare tire or roof rack Therou TJ Wrangler Technical Forum 17 01-04-2010 11:02 AM
What is the better roof rack, Garvin Exp. Rack or Kargo Master Drew99 TJ Wrangler Technical Forum 6 03-17-2009 04:33 PM
Let’s See Your Rack – Roof Rack Shopping Need Ideas… PLEASE czar97 TJ Wrangler Technical Forum 44 03-17-2009 12:26 PM
Junkyard roof rack for hardtop? ZonaWrangler YJ Wrangler Technical Forum 4 04-21-2008 10:31 PM
Alternatives to roof rack or hitch rack waterboarder JK Wrangler Technical Forum 17 02-10-2008 05:58 PM
