Junkyard Roof Rack - Page 13 - JeepForum.com
post #181 of 216 Old 12-21-2013, 01:24 PM
jscherb
Originally Posted by Submariner View Post
Attachment 932882
go down to harbor freight and get two atv racks and bolt or weld them together.
Works fine and about $350 cheaper. I would add a 6 to 8" piece in the middle just to make it a wee bit longer.
Here's a little more on that idea...
Works out really well, and if you buy the HF racks on sale you can built it for maybe $75, shown below on an XJ rack on my LJ:
Here's a whole thread on the rack project, which also shows how to do Highlift jack mounts, front light mounts, and a spare tire mount for it: http://www.jeepforum.com/forum/f11/b...asket-1089244/
I use mine on the trail all the time, it's a great place to carry an extra spare and the jack, and in the photo below I've also got a roll-aboard size suitcase up there. You can just barely make it out in this photo, but there's also a bungee net on the rack to hold things like the suitcase in place; the net was less than $20 at Tractor Supply.
Better photo of the net when the rack was off the Jeep:
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #182 of 216 Old 12-21-2013, 01:53 PM
oTTo97Sahara
First time i have ever seen this post! You'll have to excuse the snow. My baby has been parked for an 06 TJ since the 97 needs too much work right now. I put this one on from a 92 Blazer about 6 years ago. The racks are the same from the old to the new Blazers and Jimmy's so find a newer one for it to be in better shape. My JY didnt have anything newer at the time so i sanded and painted it. Used it for 4 snowboards on a 12hour trip to the mountains and it worked great. 1 plate at each corner on the inside and 8 bolts that come from the inside and nuts on the top. Never got around to trimming up the bolts but it has worked great. Used it for camping a few bunch of times too. I cannot take the supports off of this one like the ones from the expolorer but i like the looks of the one from the blazer better anyways. The only downside is that it isnt quite wide enough to stretch outside the ribs of the hard top but with the factory rubber seal that i got with the rack from the JY and some black sealant it hasnt been an issue.
I really like the looks of those ATV racks! sometimes Princess Auto(Up in Canada) have luggage racks for that mount into your receiver hitch for $50. I bet with a little cutting it would work great for a back half rack.
oTTo97Sahara is offline
post #183 of 216 Old 12-21-2013, 11:33 PM
JC_LJ
Thanks for the suggestion. I got a Conferr rack off Craigslist for cheap. They're pretty popular for land cruisers.
JC_LJ is offline
post #184 of 216 Old 01-01-2014, 04:33 PM
JC_LJ
Picked up the explorer rack last week. The cross bars need paint, so that's next. Then should be time to mount.
How much does your cargo rack weigh, Jscherb? Mine weighs about 40. Lbs and is 4x5. I only plan on putting light items up there and not loading more than 150. Otherwise I'm getting the Kargo Master bars in the spring.
JC_LJ is offline
post #185 of 216 Old 01-01-2014, 05:13 PM
jscherb
I haven't weighed it, but the shipping weight of each HF rack is 26 lbs; I didn't use the heaviest piece (the receiver tube) and also subtract the shipping carton and packing from that weight, so I'd guess it ended up in the same neighborhood as yours.
jscherb is offline
post #186 of 216 Old 01-09-2014, 02:14 PM
JC_LJ
Here's the finished product. I used some Rustoleum bed liner spray on the bars. I got the Conferr rack (now called DiamondRax) from Craigslist for $150. It's pretty stout, and I'm looking forward to putting my light camping gear up top.
I was super scared to drill through the top, and I live in Wisconsin. The weather had been cold, snow, below freezing, or I didn't have enough daylight to get it done. I spent about 3 hours on a ladder in 30* weather to get it done. So far I'm pleased with the results!
JC_LJ is offline
post #187 of 216 Old 01-09-2014, 03:32 PM
Rican142
Is it bolted right to the hard top? Or do you have some kind of support system that runs to the sport bars?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #188 of 216 Old 01-09-2014, 04:22 PM
JC_LJ
The cargo rack is mounted to the explorer cross bars and tracks
JC_LJ is offline
post #189 of 216 Old 01-09-2014, 06:58 PM
Rican142
I meant the rack to the top
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #190 of 216 Old 01-10-2014, 09:02 AM
JC_LJ
Yes the explorer rack itself is bolted directly to the top.
JC_LJ is offline
post #191 of 216 Old 03-05-2014, 07:44 PM
horn34
I picked up cargo tracks/crossbars off a 99 Exploder for $20 this weekend. The length looks pretty good to me and with 5 mounting holes on each side, it's not going anywhere.
My question is for those that trimmed/shortened theirs....did you do it because it wouldn't fit or you didn't want it running the full length of the roof? I'm thinking the more coverage, the better, gives you more cargo placement options.
horn34 is offline
post #192 of 216 Old 03-05-2014, 08:37 PM
RDaniel2405
RDaniel2405's Avatar
I set it up there before I cut it and just looked too long for me at full length. I cut mine because I thought it looked a little better, and knowing that I was not going to put too heavy of items op there. On page 10 there is a pic of my jeep with a bicycle in a box.
MY DAILY DRIVER BUILD
WTB Impact Orange half doors.
RDaniel2405 is offline
post #193 of 216 Old 03-05-2014, 09:38 PM
rbkelley89
i left mine the full length too but need to shorten them or fasten down the front i havent decided. i was thinking about shortening them because the roof isnt flat from front to back it has a slight curve and the rails are curved if they get fastened down but i guess that doesnt matter once there fastened on i was just thinking the rails would be putting too much force on the hardtop trying to go back to their normal flat form.
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #194 of 216 Old 07-21-2014, 01:04 AM
HighRoller02TJ
im taking one off an 02 ford explorer xlt this week. can anyone tell me what tools i need to bring and how long i should plan on being there to remove it? thanks
HighRoller02TJ is offline
post #195 of 216 Old 07-21-2014, 01:37 AM
horn34
A cordless drill/screwdriver with a normal size philips bit. Takes 5 minutes to unscrew. If you do it with a regular screwdriver, maybe 10 minutes.
horn34 is offline
hardtop , lj , roof rack , tj
ski rack options spare tire or roof rack Therou TJ Wrangler Technical Forum 17 01-04-2010 12:02 PM
What is the better roof rack, Garvin Exp. Rack or Kargo Master Drew99 TJ Wrangler Technical Forum 6 03-17-2009 05:33 PM
Let’s See Your Rack – Roof Rack Shopping Need Ideas… PLEASE czar97 TJ Wrangler Technical Forum 44 03-17-2009 01:26 PM
Junkyard roof rack for hardtop? ZonaWrangler YJ Wrangler Technical Forum 4 04-21-2008 11:31 PM
Alternatives to roof rack or hitch rack waterboarder JK Wrangler Technical Forum 17 02-10-2008 06:58 PM
