Junkyard Roof Rack - Page 11 - JeepForum.com
post #151 of 218 Old 04-21-2013, 06:11 PM
rbkelley89
when i do this since i dont like how high the rails sit i am going to do what i did on my durango and get these rail mounts from defender roof racks and fab up a mount with u bolts to a cargo rack to get a clean flush looking rack. has anyone gotten these? http://www.defenderracks.com/products.asp?id=69
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #152 of 218 Old 04-21-2013, 06:54 PM
jmmorgan82
2009 JK Wrangler
I found out that 1/4"-20 stainless panhead bolts work perfectly. I got the rack chopped down 11", mocked it up, and drilled the holes for it. I'll get the hardware and get it mounted up tomorrow, and I still need to strip it and paint it whenever I feel like doing so (in no hurry).
jmmorgan82 is offline
post #153 of 218 Old 04-22-2013, 08:22 PM
jmmorgan82
2009 JK Wrangler
Got her thrown on today, minus the paint. Works great and held my 12' Ocean Kayak perfectly.
post #154 of 218 Old 06-24-2013, 02:27 PM
JeepinJake75
Heading to the junk yard this weekend. great thread!!!!
Colorado Jeep Club Member #257
RED JEEP CLUB MEMBER #654
JeepinJake75 is offline
post #155 of 218 Old 08-29-2013, 01:10 AM
Rican142
Ok know it was prob already mentioned, but
1 how much weight does it hold
2 does it start flexing the hardtop with wait on it?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #156 of 218 Old 08-29-2013, 03:39 PM
toxikmo
Mines fine , it holds 4 snowboards with out any problems
toxikmo is offline
post #157 of 218 Old 08-29-2013, 04:59 PM
Rican142
Any vibrations from the top? My main thing is, I don't wanna e driving along, hit a bump, the roof flexes in and does a POP! When it does it, know what I mean?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #158 of 218 Old 11-11-2013, 08:31 PM
fordtech
Originally Posted by fordtech View Post
Question- Does anyone know what lays under those plasitc/fiberglass covers running side to side on LJ tops? I assume a metal strip, but have not tryied to find out yet, thought someone might already know. I am thinking of trying to hit one or both of those when I do my rack.
I have a Yakima Loadwarrior with after market XJ crossbars (like unistrut) I used on my XJ that I kept when I sold it. I had bike fork mounts on the outside of the rack. Would be handy to be able to reuse it and carry some reasonable loads or bikes up there when I have the hardtop on.
Now to find XJ rails.
Guys, this project never got done, but back on my mind now. Does anybody know what those cross pieces on LJ tops consist of?? I tried some heavy magnets, and no dice, so I assume it is not metal. If they are steel strips I will try to hit them plus a few more bolts, but not looking like it.
Thanks!
fuel in my veins, mountains on the brain......
Current-06 Unlimited. Past- 98 XJ, 95 YJ, some Fords.
BUFFALO NY JEEPERS-
Just your friendly neighborhood x-ford technician...
fordtech is offline
post #159 of 218 Old 11-12-2013, 07:54 AM
-JD-
Thanks!
I did this on my LJ then went to CO and back from the east coast carrying a Thule 700 pod and a cargo basket on Thule square bars & Tracker II towers attached to the long (68") XJ tracks. The pod was longer than the roof - with at least 200lbs or more on the racks - there was a good bit of heavy off-road banging when fully loaded which eventually led to a failure. The good news is that the weak point was the XJ tracks and I believe that that is preventable - which I'll address later.
Here is what I did ...
First, note that the hardtop is made up of several pieces that are bonded together. Look on the inside of the top. Along the left and the right edges of the top-horizontal section, there is a seam where the left/right vertical piece joins the top-horizontal piece. The side piece comes up and bends in with about 3/4"-1" of flat, horizontal section that is bonded to the top-horizontal piece. (The top-horizontal piece continues on the outside, curves down, and is then bonded to the side piece again, forming a longitudinal box channel - pretty strong) That horizontal, flat-bonded section on the side piece is where I located the tracks. That way they are right along the box channel, on a double thickness, and the fasteners actually hold the seam/bond together. It also give you almost the exact same spacing as on an XJ if you are using the factory cross-bars.
I used 1/4" (by 1" IIRC) Stainless, Hex-Socket-Head Cap screws with Nylock nuts inside. I backed the fasteners on the inside of the top with a full length of 3/4" x 3/16" steel.
I cut the steel to length then taped it the XJ track to mark the hole positions and then drilled the 1/4" clearance holes in the steel. The tricky part was that the steel had to be relieved where the 2 lateral cross pieces overlap the mounting area (to about 1/16" thickness - thinner stock would have to be fully cut out around it). Fortunately I have access to a milling machine so it was not hard - it doesn't need to be too precise so it could be done carefully with a grinder.
I then taped/clamped the steel to the inside of the roof and drilled up using the steel backer as a template. Notes: Take the top off to do this. The top is a fiber reinforced structure wear the proper safety equipment. Use a GOOD drill bit and go easy on the pressure to minimize breakout damage as you go through. I did not try it, but a brad-point bit might be a good choice to help minimize breakout - experimentation required.
The failure mode that I had was that the heads of the mounting screws pulled through the bottom of the XJ tracks. The problem is that the access holes on the top of the tracks for the mounting screws are not big enough for (significantly) larger screw heads or washers to be inserted to better spread the load. As I see it, two possibilities exist to get around this. I need to either fish washers into place at each hole from the ends (probably using glue or caulk to hold them in place for assembly) or I will fabricate a full length backer strip using 1/8" aluminum and insert it into the track. I will probably do the backer strip since it offers more strength IMO.
I've seen no evidence of damage to the top itself, despite the banging it took with the free floating track at the back - enough banging to crush the XJ track down about an 1/8" where the cross-bar foot was mounted.
2006 Rubicon Unlimited 6-Sp Manual - 285/75/16 Cooper ST MAXX/stock Moab wheels, Savvy Under Armor BL/MML, Savvy Step-Rocker/Sliders, Savvy/Currie Ultimate Steering, Savvy UCAs, Currie LCAs, TBs and BSs, Nth/AEV 3" Springs, Rancho 9000XLs (255s/256s), ARB D44 Diff covers, Savvy/Tom Woods HD Rubicon Rear drive shaft, Genright Safari 31gal Tank Soon: Savvy LED Lights, new engine :-(
-JD- is offline
post #160 of 218 Old 11-13-2013, 06:32 PM
Submariner
Submariner's Avatar
put a ford rack on and then welded two atv carriers from harbor fraieght together to get it done.
Submariner
Submariner is offline
post #161 of 218 Old 11-13-2013, 08:09 PM
Rican142
Why do u have a jk sticker on ur tj...(traitor)
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #162 of 218 Old 11-24-2013, 03:26 PM
rbkelley89
Fabbed the defender roof rack mounts I had on my durango to fit the explorer roof rack. Just had to bend two pieces on angle iron per mount and cut down to a total 1" width to slode into the rails. I like this much better than the roof rails. Still need to paint and get some stainless steel hardware but ima do that this summer when I paint the hardtop black
post #163 of 218 Old 12-02-2013, 01:12 PM
Submariner
Submariner's Avatar
can't spell down here in oregon,
Stands for
Southern Oregon Jeep Kulb
SOJK
Submariner
post #164 of 218 Old 12-02-2013, 08:09 PM
Rican142
Suuure it is ;P lol
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #165 of 218 Old 12-17-2013, 09:45 PM
horn34
Does anyone know of an easily sourced salvage roof rack that will fit a 2001 TJ without cutting? I don't mind cutting, but I'd rather grab one off a minivan/subaru/whatever that fits with nod mods. None of the salvage yards in Austin that I know of let you pick and pull. You have to call and tell them the year/model/make of the part you want.
horn34 is offline
hardtop , lj , roof rack , tj
ski rack options spare tire or roof rack Therou TJ Wrangler Technical Forum 17 01-04-2010 11:02 AM
What is the better roof rack, Garvin Exp. Rack or Kargo Master Drew99 TJ Wrangler Technical Forum 6 03-17-2009 04:33 PM
Let’s See Your Rack – Roof Rack Shopping Need Ideas… PLEASE czar97 TJ Wrangler Technical Forum 44 03-17-2009 12:26 PM
Junkyard roof rack for hardtop? ZonaWrangler YJ Wrangler Technical Forum 4 04-21-2008 10:31 PM
Alternatives to roof rack or hitch rack waterboarder JK Wrangler Technical Forum 17 02-10-2008 05:58 PM
