#1 | |
Junkyard Roof Rack
After pricing the roof racks at all the websites and catalogs and deciding they're all a ripoff, I took a drive to see what the local pick-n-pull had to offer. I found a mid 90's Ford Explorer Sport with a roof rack system in good shape minus about 10 years of sun and dust damage. It has two rails, two adjustable cross bars, and two adjustable rings for tie-downs. Simply removed a few screws to take it off, gave the guy $25 for it and I had a new roof rack!
It was about 11" too long to fit on my hard top, so I taped off what I didn't want and used my Dremel to cut the ends of both the rails and the plastic pieces that go under the rails. (Cutting one end would have left me without a screw hole near the end, so if you're doing this make sure you cut the end that has a hole around 12" in) Lightly sanded all the metal pieces and gave them 2 coats of Krylon black. The next day when the paint was dry I put the rack together, made sure it was square, and marked off the hard top for the first 2 holes. My top was still on its storage cart which made it much easier to work on. I loosely screwed the "top" screws in then marked the rest. I went with a total of eight screws, four per rail. As far as hardware to mount it, I used the screws that came with it as the heads fit in the rails nicely. They were metric, 6mm, and I bought 8 nuts (with the nylon inside), 8 fender washers, 8 lock washers and 16 rubber washers to fit them. I used some silicone on each of the holes to keep the water out, then put one rubber washer between the rail and the top, and another between the screw head and the rail. All in all I'm very pleased with the end product. It looks great, will accept a snowboard rack as well as other roof racks, and it only cost me about $40. $25 for the rack, $6 for paint, and less than $10 for all the hardware. Pics: the pieces as they arrived ![]() one of the tie down rings and a rail in their "before" condition ![]() rails taped to be cut ![]() rails painted up ![]() all the other hardware ready to be installed ![]() the rack mounted to the top, before the top went on ![]() the finished product! ![]() ![]() ![]() ![]()
1999 TJ (my first Jeep without a carburetor!) RE 2" BB and Moab's / MTR's, pretty much stock otherwise |
#2 |
Running Secretly Amok!
Looks great! Nice job! What did you use to seal hardware? Silicone I assume.
#3 |
Nice job!! Looks real good!!
Just an old dude in a TJ. |
#4 |
wow nice work it looks sotre bought and expensave good job!
i buult my own roof basket and im making 2 more for friends of mine
http://i7.photobucket.com/albums/y27...ow/jeep005.jpg Alpinestars Racing Ahead.... HOOD VENT/ LOUVER SALE Click Below http://www.jeepforum.com/forum/f129/hood-vents-sale-grand-prix-camaro-1020397/ |
#5 |
man that looks sharp on a hardtop, wish i had a hardtop now
-00 Mildly Modified Wrangler SporT-Sold SILVER JEEP CLUB MEMBER #55 |
#6 |
Fantastic. great work! I may borrow your idea.
AMERICA IS FULL |
#7 |
ΜΟΛΩΝ ΛΑΒΕ
looks good
'99 Gunmetal TJ Blue Jeep Club Member #256 4" RC X-Series, 1in BL Rokmen Armor KC Day Lighters, 33 BFG M/T with more to come OlllllllO |
#8 |
Thanks for all the compliments guys!
Just some silicone caulk I had in the garage. That plus the two layers of rubber washers should keep the moisture out. If not, it's still a Jeep inside- it'll live. ![]()
#9 |
was this a oem ford explorer rack?
#10 |
Great work..
2 questions for ya. 1. Could you post a pic of the inside attachements? 2. Any extra wind noise? I've been wanting to do a roof rack, but I've heard horror stories about whistling at highway speeds and such. Again, looks good and great work singleshot
If it has fasteners, I can take it apart.... Putting it back together is the real question....... |
#11 |
Looks great....Might consider something like it in the near future...
You gonna put a basket on it?
1999 TJ
#12 |
Some Call me RockDog
turned out pretty good. any interior photos of the bolts? Anything special with the bolts you used?
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#13 |
Great Job, it looks factory.
#14 |
that looks great. i may copy that idea
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#15 |
That looks real sweeeeet. I'm gonna steal that idea as well.
BTW .. while you have that spray paint out, you might want to touch up that pass side door mirror ![]()
---------------------- Formally 88Jeepster ---------------------- Who's in front ? Ridin' topless again .. sweet !! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
