Jump start = Volt Meter spikes while driving then wont start - JeepForum.com
post #1 of 6 Old 02-21-2010, 10:45 AM Thread Starter
AWILD
AWILD's Avatar
Just looking to see what I'm up against here. My guess is alternator? Here's the details:
Got in an accident the other week and had to jump it afterwards to get it to start. Drove it home and during the drive the volt meter spiked to 19V+. Ended up only doing that for about 5 mins and went away. Shut the car off after about an hour drive home and it immediately had nothing when I turned the key. No crank, no beeps, no lights, nothing. Put a tester on the battery and it showed 12-13V. Took battery out and had autozone test it, good battery.
Alternator?
(ps this is a 2000 TJ 2.5L manual trans)
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline
post #2 of 6 Old 02-21-2010, 11:30 AM
Stu Olson
Stu Olson's Avatar
The most common problem for the symptom you described is a poor connection at the battery. The cables degrade over time and if your vehicle has some age on it (not to mention white/green mung junk that grows on the battery cable connectors), it's time to replace them.
I've seen a lot of TJs fixed by doing this. Of course, it could be another problem, but I would start with a careful inspection and proceed as appropriate. Don't forget the negative cable is just as important as is the positive.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #3 of 6 Old 02-21-2010, 12:26 PM Thread Starter
AWILD
AWILD's Avatar
Yeah I'm going to take it to my shop today and check all the terminals (which appear ok at the battery end), check them at the alternator side, put the voltmeter on the alternator and see what happens from there.
TJ
AWILD is offline
post #4 of 6 Old 02-21-2010, 12:48 PM
dlporter
2011 JK Wrangler
Keep in mind that cables can sometimes degrade inside the insulation. Everything will look good upon visual inspection, but the cables are really shot.
dlporter is offline
post #5 of 6 Old 02-21-2010, 12:56 PM
sxysouthtx
We had a lot of Humvees in Iraq do this. Ordinarily there was a huge spike, and it would fry the lines. The battery would usually be fine afterwords. The alternator's voltage regulator would twist from it's position and cause the power surge. But an alternator on a jeep is much different.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #6 of 6 Old 02-21-2010, 05:37 PM Thread Starter
AWILD
AWILD's Avatar
FIXED - We ended up taking the starter, battery, and alternator to autozone to get tested. All tested fine. Signs then pointed to a bad connection somewhere. So we wire brushed all the connections and wires for the starter, battery, and alternator. Fired right up (with a belt squeal lol...fixed that too witha 15mm socket)
TJ
AWILD is offline
2.5 cranks but wont start...Cold start SnowdogMarc YJ Wrangler Technical Forum 4 08-04-2009 07:16 PM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 04:13 PM
check gauges lit..voltage meter tops to 19 and wont start! kittennocturne TJ Wrangler Technical Forum 0 03-03-2009 06:17 PM
Jeep died while driving, turns but wont start vtjeepguy97 Wrangler General Discussion 3 12-28-2008 10:45 AM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
