Johnny Joints vs. Metal Cloak Duroflex Joint - Page 38 - JeepForum.com
 3Likes
post #556 of 785 Old 02-05-2013, 12:43 PM
geiman
Originally Posted by gmbnt42 View Post
regardless, this isn't even a concern.
ftfy
geiman is offline
post #557 of 785 Old 02-05-2013, 12:56 PM
Imped
Imped's Avatar
I've got them. I won't have time to install until Thursday or so. It's not exactly a quick process.
OlllllllO
IndyORV
Imped is offline
post #558 of 785 Old 02-06-2013, 10:52 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Is it possible to mount a shock to a control arm with the MC joints at both ends? I know that it is not if you run JJs on both ends due to the design of the JJ. The control arm would just flop around.
So would the control arm with the MC joints not flop around with a shock mounted to it?
Mail crawling.
MisfitSeven is offline
post #559 of 785 Old 02-06-2013, 10:57 AM
GMBNT42
Well, I bit the bullit, ordered up a set of MC SA's............will probably run them just till the end of summer though, then resell them....hopefully my LA kit by then is complete.
Going to be running ORI STX 12" struts front and back as well. Going to be pulling the trigger on those next week.
GMBNT42 is offline
post #560 of 785 Old 02-06-2013, 11:03 AM
MotoSoul
This has me so confused.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline
post #561 of 785 Old 02-06-2013, 11:10 AM
Imped
Imped's Avatar
How do you plan on fitting ORI's in the rear? Hell, even the front will be an exercise. I feel like you're doing things without knowing how to do them and are not thinking about the details.
OlllllllO
IndyORV
Imped is offline
post #562 of 785 Old 02-06-2013, 11:19 AM
ftgiles
Originally Posted by imped View Post
how do you plan on fitting ori's in the rear? Hell, even the front will be an exercise. I feel like you're talking about doing things without knowing how to do them and are not thinking about the details.
fify
ftgiles is online now
post #563 of 785 Old 02-06-2013, 11:33 AM
GMBNT42
Your kidding right? Outboarding them. Plenty of room. I run MT CLassic III 15x7" rims with roughly 3.5" BSing on 10.5" wide tires........will be using these brackets from TMR: http://www.tmrcustoms.com/store/inde...oducts_id=1093 and these: http://www.tmrcustoms.com/store/inde...oducts_id=1094 Will be able to cut off the spring perches/shock buckets front/rear and F/R axle shock mounts. Weld on tabs to the top of the axle tubes for the bottom strut mounts. Tons of room to do this.
When you dont have to run seperate springs, shocks, bumpstops, and the large pads/buckets required you gain ALOT of mounting options.
GMBNT42 is offline
post #564 of 785 Old 02-06-2013, 11:34 AM
Ironhead
easy guys, GBMNT is never wrong
Ironhead is online now
post #565 of 785 Old 02-06-2013, 11:41 AM
Imped
Imped's Avatar
Your kidding right?
Not one bit. 2" shock bodies fit fine with the stock axles and 3-4" BS. The ORI's are 3.25" in diameter, that's massive. They wont' fit as easy as you're thinking. When you get around to articulating the axle, you'll see that. You can set that tower back into the frame rail as far as you can and you'll still have to balance the body hitting the frame at full droop and the tire at full tuck. I'm not saying it's not doable but even with little backspacing and frenched towers, you'll have a tough time finding a route outside of running them through the tub. If you can do that, you'll be the first I've seen. And that's not not even to mention the fact that I highly doubt you need them.
OlllllllO
IndyORV
Imped is offline
post #566 of 785 Old 02-06-2013, 11:42 AM
GMBNT42
Rarely.
GMBNT42 is offline
post #567 of 785 Old 02-06-2013, 11:47 AM
GMBNT42
Not one bit. 2" shock bodies fit fine with the stock axles and 3-4" BS. The ORI's are 3.25" in diameter, that's massive. They wont' fit as easy as you're thinking. When you get around to articulating the axle, you'll see that. You can set that tower back into the frame rail as far as you can and you'll still have to balance the body hitting the frame at full droop and the tire at full tuck. I'm not saying it's not doable but even with little backspacing and frenched towers, you'll have a tough time finding a route outside of running them through the tub. And that's not not even to mention the fact that I highly doubt you need them.
Yes I am aware of their diameter. Its basically no different than fitting a coilover. Doing a quick mockup, not worried about full tuck #'s or tire clearance. Full droop looks like there won't be much issue either.
My only debate is going with a 10" or 12" travel setup. Ill be starting off on SA's but will be running a LA setup by next fall. The front's will be a snap. And actually save me some weight in the process. The rear's won't be too difficult either. Quite a few people have outboarded the rears without clearance issues.
As for whether or not I need them. They simplify everything. No need for bumpstops, seperate coil/shock mounts.........which means uptravel concerns are virtually elimiated due to things like coil bind height, mount constraints etc......since new mounts are being installed, it allows me to maxmise all the available uptravel necessary. It also now solves the front tracbar hitting the diff cover on uptravel too, since I can now locate that in double sheer alignment up tighter to the OUTSIDE of the frame rail, instead of down lower on the inside. See where Im going with this?
Cost also,....these also end up being a cheaper solution. No bumpstop kit, sperate coils, shocks needed. And these I think have a slightly smaller OD vs. the 6paks............those were in reality going to run me $700 a corner including bumpstop kit. These Im under $600.
GMBNT42 is offline
post #568 of 785 Old 02-06-2013, 11:51 AM
aparke4
:thumbs up:
aparke4 is offline
post #569 of 785 Old 02-06-2013, 11:52 AM
ftgiles
Rarely.
It's not the things you don't know that will get you into the most trouble in life. It's the things you know for sure that end up being wrong. Like your skinny tire theories and slipping the clutch is the same as a torque converter.
post #570 of 785 Old 02-06-2013, 12:06 PM
Imped
Imped's Avatar
Believe me, I've covered all of those issues and more through my thought process and I still run shocks and coils and even built a frame around them....I discovered ORI's back in 09. They simplify some things but complicate others, as you'll see. They won't fit as easily as you are thinking, I promise. If you want to run them, your first concern should be your axle width.
Anyway, that's completely OT from this thread. My bad.
OlllllllO
IndyORV
Imped is offline
Savvy or Metal Cloak JDXX TJ Wrangler Technical Forum 31 06-26-2013 07:31 PM
Haven't read anything yet on the new metalcloak Duroflex joints 26679cj5 TJ Wrangler Technical Forum 40 08-29-2012 02:44 PM
Metal cloak? awinski JK Wrangler Technical Forum 6 02-28-2012 02:38 PM
metal cloak fenders? HawksJeep46 Wrangler General Discussion 9 03-30-2011 05:18 AM
RE superflex joints / Currie Johnny Joints HMTwin TJ Wrangler Technical Forum 2 04-24-2007 05:15 PM
