JKS vs. ROKMEN vs. Currie vs. Rokkrawler control arms - JeepForum.com
post #1 of 126 Old 01-24-2009, 07:39 PM Thread Starter
jmalys
From what I could research, these seem to be the best aftermarket short arms out there, if one was going to use and Old Man Emu suspension as a starting point. If you were building this set up, witch one would you go with and why? johnny joint vs. rubber bushing is sort of a perplexing question to me as well. Will the rubber bushing that JKS uses be quieter/better riding on the road??
jmalys is offline
post #2 of 126 Old 01-24-2009, 07:40 PM
never monday
add Clayton to your list
never monday is offline
post #3 of 126 Old 01-24-2009, 07:43 PM
sportcoupe
The Rock Krawler arms are the best value for sure. I'm not saying they are THE best but they are very well made. Solid stock is hard to bend or break.
sportcoupe is offline
post #4 of 126 Old 01-24-2009, 07:53 PM
Bigbob
Bigbob's Avatar
I'd go with JJ's on both ends. That leaves Rokmen or Currie.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #5 of 126 Old 01-24-2009, 08:32 PM Thread Starter
jmalys
claytons
I just went to clayton's site and did not see any short arms from them. Did they used to have these?
jmalys is offline
post #6 of 126 Old 01-24-2009, 09:05 PM
JJs99TJ
David @ Northridge sells the Clayton arms, but they are pricey IMO:
http://northridge4x4.com/products.php?cat=126
http://northridge4x4.com/proddetail....LAYTON-CA-SLCA
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #7 of 126 Old 01-25-2009, 12:00 AM
cgmrdc
1988 MJ Comanche
what about rubicon express?
get some adjustable with the super flex joints... i lovedm on my xj and lovem on my tj!
also ive read jjs on both side isnt good for dd, the ride is harsh and they bind... but thats just what ive read, only experience i have is with re...
cgmrdc is offline
post #8 of 126 Old 01-25-2009, 08:21 AM
SeanCucf
I'm going with currie's to compliment my soon-to-be OME "lift". All I've read about JJ's(on both ends), from credible sources, is good.
SeanCucf is offline
post #9 of 126 Old 01-25-2009, 08:30 AM
never monday
Clayton doesn't actively promote his SA kits. He's known for the LA parts. You have to call him for them.
That isn't bad when compared to the others in the category. Calyton's arms are 2x2 square and .250 wall. Unconditional warranty. bend one and he'll replace it.
post #10 of 126 Old 01-25-2009, 08:39 AM
Pillswoj
True Currie johny joints both end are fine in a daily driver, I would definitely look at Currie, Rokmen, or Clayton. If you are looking at buying parts separately, go with above for the front and put the Rock Krawler 4 link in the rear.
Friends don't let Friends run Bosch
Pillswoj is offline
post #11 of 126 Old 01-25-2009, 09:09 AM Thread Starter
jmalys
Same
Same exact lift I will be building. If your ultimate goal is 33" tires I think OME plus one of the above said control arms / JKS track bars/ 33 engineering TT skid are the way to go for sure.
jmalys is offline
post #12 of 126 Old 01-25-2009, 09:39 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've read somewhere that folks with usernames that don't include any vowels aren't very smart and tend to pass along unsubstantiated rumors with no personal experience to back them up.
They also tend to recommend what they currently run as if it's better than sliced bread without taking into account that there may be far better choices available. I suspect this is due to the non inclusion of vowels and their credibility should be placed somewhere near the bottom of anyone's veracity meter.
Just what I've read, so it must be true.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #13 of 126 Old 01-25-2009, 09:40 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That stuff is great if you're building bridges and trailers.
I am Savvy
mrblaine is offline
post #14 of 126 Old 01-25-2009, 09:42 AM
never monday
just following the JF moto
"bigger is better"
post #15 of 126 Old 01-25-2009, 09:57 AM
cgmrdc
1988 MJ Comanche
wow all said was "its what ive read" followed by "only experience i have is with RE"
i suggested re because like their product, never did i say it was the best choice... just another one...
I guess people with 7000+ posts know everything and people with many fewer cant possible know anything because the dont post all over JF... my mistake...
at least i was contributing... both your posts on this thread have been bashing two other users.
and wtf does no vowls in my sn have to do with anything?
and i apologise jmalys for getting off topic but it really pisses me off when people act like Mr Blaine has, very conterproductive. if youve got a problem with me take it up in a pm!
cgmrdc is offline
Rokmen vs. BDS Control Arms? 2ndmardiv TJ Wrangler Technical Forum 53 07-23-2010 08:47 AM
rokmen or currie short arms pumpman55 TJ Wrangler Technical Forum 7 12-25-2009 11:03 AM
Rokmen vs Currie Adjustable Control Arms illinijeep TJ Wrangler Technical Forum 14 01-15-2009 07:33 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 07:26 PM
Anyone with Currie control arms? kpatrick TJ Wrangler Technical Forum 5 12-22-2004 11:26 AM
