Quantcast JKS trackbar rattling loudly - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > JKS trackbar rattling loudly
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 06-21-2009, 09:21 AM   #1
zband
I lifted my jeep about 2 years ago and with the kit came a JKS adjustable front trackbar. The end of the trackbar that bolts to the frame (ie on the drivers side ) rattles to no end going over small bumps and even when turning the steering wheel back and forth. This is driving me crazy. My mechanic says to get a rebuilt joint kit since this is a common failure point. I call JKS tech- he says he's never heard of it failing. I even tried tightening to 110 ft-lbs - still rattles.
Suggestion?
zband is offline   Reply With Quote
Old 06-21-2009, 09:37 AM   #2
Kiwi
Kiwi's Avatar
Suggestion?
Is it in the joint or is the bolt allowing movement? Do you have a washer on the top of the frame mount before the nut? If so, you need to take it off since you can't hold the torque correctly. The installation instructions are clear about this, but more people than not seem to ignore this or don't read the instructions.
Have someone turn the steering wheel back and forth while you are under the front and you should be able to tell if its attachment to the frame mount, or the JJ itself.
The JJ itself is not a common failure point.
Kiwi is offline   Reply With Quote
Old 06-21-2009, 09:44 AM   #3
zband
the bolt does not seemed to move it seems the joint itself is making the noise.
Old 06-21-2009, 09:49 AM   #4
Kiwi
Kiwi's Avatar
You need to rebuild the joint then.
Old 06-21-2009, 09:52 AM   #5
Unlimited04
Unlimited04's Avatar
x2. you need to grease the piss out of it frequently. and they still wear out. rebuild it
Unlimited04 is offline   Reply With Quote
Old 06-21-2009, 10:13 AM   #6
otisdog
I've had a Pro Comp on for 6 years and the joint is still tight as hell.
Jim
03 Sport
otisdog is offline   Reply With Quote
Old 06-21-2009, 12:01 PM   #7
mudb8
want it rite or rite now?
mudb8's Avatar
I have installed many jks bars on the various differnt tj frame end brackets.... the washer needs to be used on some to get it torque correctly....
I also find it hard to belive the jj has failed in a track bar application, evenif it was never greased.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Glock Forum
