JKS Trackbar bushings - JeepForum.com
post #1 of 2 Old 06-08-2008, 07:50 AM Thread Starter
NameUnavailable
NameUnavailable's Avatar
When I got my new rims and tires installed the other day, I also got a professional alignment since I had it there. They told me the bushings in my trackbar were worn. I found the parts on JKS's web site. Only run me around $43, so it's not horrible. Has anyone else had to change these? How much of a PITA is it? Am I gonna need a press or anything? Any writeups?
I just installed this last July, kinda short life. I'm sure this is the cause of my recent death wobble. I suspect one of my old front tires was out of balance, could this have caused it to wear out? Anyone else having these wear out quickly? Anything else I should be looking at?
This diagram is from the JKS site. I am planning to replace A, and F, K, H, I and M (The last 5 are a package and come together). It looks like the frame side is popping out the snap ring, and the rest will just pull out. Not sure about the axle side.
A OE Rubber Bushing
F Preload Washer
H Polyurethane Bushing (supplied with F)
I Snap Ring (supplied with F)
K Preload Washer (supplied with F)
M Polyurethane Bushing (supplied with F)
NameUnavailable is offline
post #2 of 2 Old 06-09-2008, 06:05 PM Thread Starter
NameUnavailable
Just bumping once for the evening crowd. Gonna give JKS a call in the morning.
Are Trackbar Bushings interchangable? rallynut78 TJ Wrangler Technical Forum 15 03-01-2009 08:13 PM
Will I need a trackbar relocation bracket with rear adjustable trackbar FLATFENDER54 TJ Wrangler Technical Forum 3 02-05-2009 03:35 PM
Where can I find new bushings for trackbar? james509 TJ Wrangler Technical Forum 14 01-02-2008 06:16 PM
track bar bushings and sway bar bushings 1CleanTJ TJ Wrangler Technical Forum 1 12-28-2007 06:04 AM
Bushings with RC Adj Trackbar carr51 TJ Wrangler Technical Forum 2 09-11-2007 10:56 PM
