JKS adj trackbar hitting DANA 30 diff cover ! - Page 3 - JeepForum.com
post #31 of 37 Old 02-22-2009, 09:53 AM
mudb8
want it rite or rite now?
mudb8's Avatar
shock length is what actually determines the bumpstop height, followed by tire size if they aren't enough.
the 32's usually only need 1" stops. the 2" should take care of the track bar contact.
say you have 25.5" long shocks (fully extended), 2.5" lift and 32's.... you need 2" bumpstops, even though the tire clearance is good with 1" stops because the shocks bottom out with 1" stops before the bumpstops stops contact the axle.
the easiest way to find out is to remove both front springs and drop the frame on the axles, you can raise and lower the frame to determine where and when contact is made...
flexing will prodce different results and may not even hit due to one side drooped and the other fully/partially stuffed.
a speed bump stuffs both tires at the same time and jams/rebounds the control arm bushings.... something esle, how are your control arm bushings?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #32 of 37 Old 02-22-2009, 10:45 AM Thread Starter
jeep2008
you are saying that (something else, how are your control arm bushings?) because of my skyjackers,aren't you?
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #33 of 37 Old 02-22-2009, 05:35 PM
mudb8
mudb8's Avatar
lol, yep, but I didn't look at your profile to see if you stated what control arms you have... the stock ones can end up with quite abit of slop when they get worn out.
non adjustable skyjacker's are a 1/4' longer than the stock arms if memory serves... 16" vs. 15 3/4"
mudb8 is offline
post #34 of 37 Old 02-24-2009, 02:52 PM Thread Starter
jeep2008
here is the contact with the track bar
there is also a mark on the upper side of the trackbar,any ideas why??
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #35 of 37 Old 02-24-2009, 02:55 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yup my stock track bar rubs the Riddler diff cover in the exact same spot.
maybe adjustable lower and upper control arms and move the axle back 1/4"? other than that...i think we'll have to heat up the bar and dent it, then weld some support on the backside.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #36 of 37 Old 02-25-2009, 04:14 AM Thread Starter
jeep2008
I used these http://www.4wd.com/productdetails.aspx?partID=7088 in my lower ca to fix a little my caster after the lift,could it be that i turned the axle a lot and now it is hitting?they don't have a big range though
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #37 of 37 Old 02-25-2009, 07:49 AM
crgrissom
Master of Reality
crgrissom's Avatar
Looks like you do need to back it off, and also you may want adjustable uppers so you can fine tune it all...caster, pinion angle, axle position (wheelbase). The right settings may be a compromise, but will eliminate your rubbing.
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
Inverted T steering hitting front diff cover! yippieayae TJ Wrangler Technical Forum 11 04-17-2011 07:09 PM
Is this a Dana 30 SOLID diff cover? TJamz TJ Wrangler Technical Forum 9 10-29-2009 09:26 AM
WTF! Took all the bolts out of diff cover...tried hitting it, spitting at it, and... JeepinYahoo TJ Wrangler Technical Forum 6 07-23-2006 08:02 PM
Dent in dana 44 diff cover Buckeye Bill TJ Wrangler Technical Forum 13 12-10-2005 07:43 PM
Diff cover hitting gas tank skid UCTJ TJ Wrangler Technical Forum 7 08-21-2005 10:04 PM
