JKS 1.25 bl install question - JeepForum.com
post #1 of 7 Old 11-04-2013, 05:19 AM Thread Starter
Vic99TJ
So I got the JKS 1.25 bl and 1 mml. Gunna be installing this week. My one question is I have access to a shop. How does the install differ if you have a automotive lift? Can I remove all the bolts and just lift the body or one side at a time? Thanks
Sent from my 03 Rubi!!!
OnlyAjeep
Vic99TJ is offline
post #2 of 7 Old 11-04-2013, 05:44 AM
Timido
If you have a lift I woul take the body mount bolts out. Put the long bolts in and lift the body up so it stays in line with the mounts.
Timido is offline
post #3 of 7 Old 11-04-2013, 04:36 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
You can loosen all the bolts, only remove one side at a time...
Knuckelhead is offline
post #4 of 7 Old 11-04-2013, 06:55 PM
doclouie
X2 or you will be sorry.
2000 Sahara, 3.5" Rubicon Express Lift, 1" spring spacer & 1" Body Lift, 35" BFG Mud tires, Front & Rear ARB, Rancho 9000 shocks, UCF Ultra High Belly Up Skid.
doclouie is offline
post #5 of 7 Old 11-05-2013, 08:29 AM
drandersoninc
drandersoninc's Avatar
x3 And the reason would be that if the tub somehow shifts while all the bolts are out its a PITA to get everything realigned. Keeping one side in (loose, but engaged), prevents that.
drandersoninc is offline
post #6 of 7 Old 11-05-2013, 08:34 AM
sjones26573
x4
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #7 of 7 Old 11-05-2013, 08:50 AM Thread Starter
Vic99TJ
Thanks
OnlyAjeep
Vic99TJ is offline
