07-14-2012, 01:50 PM
#1
Smooth....
JK springs and shocks on an LJ
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
07-14-2012, 01:51 PM
#2
Smooth....
Just as an FYI. your results may vary. I have no winch or any heavy bumpers just the stockers.
KCCO!
08-04-2012, 05:10 PM
#3
Thanks for posting this. I had heard conflicting stories if it was possible or not and a friend sent me his Rubicon springs & shocks so I've been anxious to test it out. What BPE's did you go with?
'85 CJ-7
'05 Rubicon LJ
'12 Sahara JK
08-04-2012, 06:38 PM
#4
Are you going to add spacers to the front to level it out?
Originally Posted by Imped
Rustys blows big, fat camel nuts.
08-04-2012, 07:29 PM
#5
I probably will end up adding them but I don't have them yet. I wanted to get the springs on to see how it looks before deciding. AEV has their front spacers on sale right now so I might go ahead and pull the trigger on them.
'85 CJ-7
'05 Rubicon LJ
'12 Sahara JK
08-04-2012, 07:36 PM
#6
Conga-rats
and
MOAR lights!
2006 LJ
08-04-2012, 08:01 PM
#7
Viewer Discretion Advised
I'm running OME 2.5" springs on my LJ with JK Unlimited shocks as well, and it rides great. It's just a bit of a chore getting the bar pins out of the factory LJ front shocks to switch over to the JK shocks if you aren't using bar pin eliminators.
08-05-2012, 06:18 AM
#8
Smooth....
I used jks bpe's after looking at it I bought a simple 6 ton shop press. Made it so much easier. And I now installed some jks acos in the front
to now level it off. Still need to adjust them a little but its better now
KCCO!
08-05-2012, 07:44 AM
#9
OK.......so exactly what was the point of swapping out to JK springs(And then cutting them) and shocks? Im failing to see any real benefit on or off road here..........
08-05-2012, 07:53 AM
#10
Over it
I believe he cut some out of the bottom center so it would sit in the lower spring perch instead of replacing the spring perch.
LJ Owners Group member #431.
08-05-2012, 08:08 AM
#11
Yeah, I understand that, but the question is what was the whole point of the whole project?
08-05-2012, 08:10 AM
#12
Maybe they were free take-offs, so there's that...
EDIT: Ok, maybe inexpensive
#13
Smooth....
Well I gained lift and ride comfort for parts that cost me under $300 total, springs shocks bpes and acos. And gained around 2.5 inches of lift. Plus smoother ride. Not sure why you wouldn't want that.
KCCO!
08-05-2012, 08:15 AM
#14
Crank up those ACOS!
08-05-2012, 08:19 AM
#15
Smooth....
Lol yeah yeah I know. I was rushing when I put them in. And only set them at as close as possible to start. Will have to break out the jack and spring compressors this week sometime.
KCCO!
