JK shocks on TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > JK shocks on TJ
Rough Country Deals at JeepHut.comEliminate Hood Flutter!!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-27-2014, 05:31 PM   #1
jeff408
JK shocks on TJ
I think I read somewhere you can use stock JK shocks w/ 2" spacer lift on TJ's. Anyone heard of this or have done it?
jeff408 is offline   Reply With Quote
Unread 03-27-2014, 05:39 PM   #2
2jhanna
Yep, have you tried doing a search?
jhanna
denton county, tx
2jhanna is online now   Reply With Quote
Unread 03-27-2014, 05:40 PM   #3
pcoplin
I used rear Rubicon shocks all the way around on my lifted Wagoneer. The red Rubicon ones are longer than stock. I think they were 15/23 collapsed/extended.
Edit: real nice shocks though. Similar to Bilsteins.
98 TJ 5.9/46RE/D300
85 Wagoneer 5.2/44RE
01 F250 Powerstroke 7.3/ZF6
Ultra4 KOH #689 car
pcoplin is offline   Reply With Quote
Unread 03-27-2014, 05:57 PM   #4
jeff408
Yea I tried to search " jk shocks". and nothing anyway thanks for the replies guys. Thats what I have is the red ones off the Rubicon.
Unread 03-27-2014, 06:49 PM   #5
77351wcj5
You will need mandatory bump stop extensions or you will break some stuff. All rigs are different, but 1.5" front and 2" rear may be close - check it and see.
77351wcj5 is offline   Reply With Quote
Unread 03-27-2014, 07:17 PM   #6
RubiDee
Works like a dream, I have 2" BB and installed reg JK shocks 6 mos ago, press out bar pins and spread rear mounts an 1/8" or so but easy job..
RubiDee is offline   Reply With Quote
