JK D44 rear axle in a TJ? talk me into/out of this - Page 2 - JeepForum.com
post #16 of 16 Old 08-12-2010, 07:45 AM Thread Starter
Faramir66103
It seems the Ox locker is available in 30 spline count, so that should mate up? Does a higher spline count always equate to a larger axle diameter for a given axle model? I emailed both Superior and Ox with a number of questions and will report back how they respond.
Thanks,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
jk , tj , wrangler , d44 , dana 44 , axle , swap , advice , help
Rear Axle / Rear Tire Clunking After Exiting Expressway czar97 TJ Wrangler Technical Forum 8 12-12-2011 09:18 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Solid Axle Hd 44 Rear Axle Assembly SuperWade2 TJ Wrangler Technical Forum 128 06-05-2009 12:01 AM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
Rear trackbar bracket? Drilling? Rear axle shift thebulkinator TJ Wrangler Technical Forum 5 04-03-2005 08:17 AM
