JK axle swap to TJ - Page 2 - JeepForum.com
post #16 of 25 Old 03-24-2011, 09:02 AM
shrubeck
Lol silly manual transmissions and their need for e-brakes.
My 9" won't be getting an e-brake either
Do you know what the "e" in e-brake stands for? I suppose if you loose your brakes coming down a hill you just jam it in park right? Let me know how that works out.
That's what she said.
shrubeck is offline
post #17 of 25 Old 03-24-2011, 10:25 AM
RogueSpear2023
E=Emergency, the e-brake is also commonly refered to as the parking brake. And no you don't just jam it in park, because if you do you will shear the parking pin basically putting you in neutral, and if you survive you will have to take the transmission apart to fix the parking pin. Driving with out a e-brake is extremely dangerous and not recommended, not to mention the liability of not having one. It provides a mechanical link to you brakes if your hydraulic brake system fails.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #18 of 25 Old 03-24-2011, 12:53 PM
HemiTJ
Originally Posted by bbr0w View Post
I have a question: What did you guys do about the speed sensors? Did you just splice the old cables to the new speed sensors?
-Bryan
I don't have ABS, So I just cut the wires off, I left the sensor in so it would plug the hole.
HemiTJ is offline
post #19 of 25 Old 03-24-2011, 10:37 PM
Bennettj13
When I'm coming down hills I'm in low gear and 1 anyways. Engine braking is a wonderful thing.
As for the speed sensors, I don't have ABS. I cut the wires off. If you take the plug out, mud and **** will get inside.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #20 of 25 Old 03-24-2011, 10:48 PM
SpeedJeep
SpeedJeep's Avatar
I thought you could buy JK axles made for TJ straight from Chrysler now?
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #21 of 25 Old 03-24-2011, 11:01 PM
Bennettj13
You can, but they are more expensive, have a 5x4.5 bolt pattern, and are more narrow. Finding JK take-offs, or someones project crate axles like I got, work out much better. Well, they did for me at least.
post #22 of 25 Old 01-15-2012, 08:59 PM
Heath
2014 JK Wrangler
I know. It's super funny when you have an auto and are relying on "park" and the transfer case pops out of 4low into neutral like happens ALL THE TIME on TJs and LJs!
2013 JKU Rubicon
Heath is offline
post #23 of 25 Old 01-15-2012, 09:05 PM
Heath
2014 JK Wrangler
A buddy broke a ba joint on a ledge and lost the wheel while being lowered down a hill. He lost the knuckle and caliper and all and subsequently the brake line and brakes. E brake was all he had, and a it did was slow him down. Hate to image what would have happened if he would have gone down full out. Throwing it in park would have just made it skip off the pawl, and if it would have grabbed it would have broke the tranny or flipped the Jeep backwards.
2013 JKU Rubicon
Heath is offline
post #24 of 25 Old 07-06-2012, 10:28 AM
dsjk
2011 JK Wrangler
Resurrection!
as I am starting this swap in a few weeks to give my TJ dana 44 front and rear
Originally Posted by voodooJK View Post
Something you said after the fact exposed that part of me... like a catholic school girl normally would.
dsjk is offline
post #25 of 25 Old 07-19-2012, 03:55 AM
bbr0w
Let us know how it goes -
bbr0w is offline
jk , tj , wrangler , axle , swap , help , advice
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
d30 yj to tj axle shaft or full axle swap? Rocky_Cosmark YJ Wrangler Technical Forum 3 02-14-2010 10:48 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Gear Swap or Axle Swap? Zazoos YJ Wrangler Technical Forum 3 06-02-2009 11:29 PM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
