JK axle swap to TJ - JeepForum.com
post #1 of 25 Old 07-22-2010, 07:41 PM Thread Starter
JK axle swap to TJ
Can I see what those of you who have swapped JK axles in to your TJ have done for the rear e-brake? What did you do about the tabs for the e-brake lines on the axle (they are right where I want my lower control arms to go), and what e-brake lines did you use?
????? is offline
post #2 of 25 Old 07-22-2010, 08:06 PM
Bennettj13
I didn't ever re-connect it.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #3 of 25 Old 07-23-2010, 11:23 AM Thread Starter
Anyone else that did reconnect it?
????? is offline
post #4 of 25 Old 07-26-2010, 01:31 PM Thread Starter
ttt
????? is offline
post #5 of 25 Old 07-26-2010, 01:49 PM
Apex
Recon death squad
Apex's Avatar
Lol silly manual transmissions and their need for e-brakes.
My 9" won't be getting an e-brake either
Apex is offline
post #6 of 25 Old 07-26-2010, 02:58 PM
Commando81
I need a functioning Ebrake for inspection.
Commando81 is offline
post #7 of 25 Old 07-28-2010, 09:11 PM Thread Starter
I have an auto, but the e-brake is still nice to have.
????? is offline
post #8 of 25 Old 01-26-2011, 02:49 PM
Madeoflite
Bump ???
Madeoflite is offline
post #9 of 25 Old 02-22-2011, 11:22 AM
bbr0w
Did you ever find a solution for the e-brake?? If not, you can use the Lokar e-brake kit for a Ford Explorer with an 8.8. You can order the kit from Summit Racing, or JEGS.
bbr0w is offline
post #10 of 25 Old 02-22-2011, 06:03 PM Thread Starter
Do you have pictures of this? The TJ and JK have different methods of attachment for the e-brake by the drum.
????? is offline
post #11 of 25 Old 02-22-2011, 07:59 PM
HemiTJ
I put JK axles in my 97 TJ and I used the factory JK lines up to the TJ junction/ adjuster.
HemiTJ is offline
post #12 of 25 Old 02-23-2011, 05:36 PM
bbr0w
I didn't have the cables that came with the JK axles - so the kit I purchased was for an 8.8 Ford, which hooks over a lever, but you can spread the clevis and use a 1/4" bolt for attaching.
bbr0w is offline
post #13 of 25 Old 02-23-2011, 06:41 PM
BLUZTJ
I had e brake cables from disc brakes, and used a 1/4 bolt to attach.
BLUZTJ is offline
post #14 of 25 Old 02-23-2011, 06:45 PM
BLUZTJ
I used the e brake cables from 35 disc brake, and used a 1/4 blot to attach to the JK 44.
BLUZTJ is offline
post #15 of 25 Old 03-24-2011, 07:30 AM
bbr0w
I have a question: What did you guys do about the speed sensors? Did you just splice the old cables to the new speed sensors?
-Bryan
bbr0w is offline
jk , tj , wrangler , axle , swap , help , advice
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
d30 yj to tj axle shaft or full axle swap? Rocky_Cosmark YJ Wrangler Technical Forum 3 02-14-2010 10:48 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Gear Swap or Axle Swap? Zazoos YJ Wrangler Technical Forum 3 06-02-2009 11:29 PM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
