#1 | |
Jerry Cans
I want to add 2 Jerry cans to my Jeep as a "just in case"...
So I have been looking in Q-Tec and 4wd catalogs for some type of mounting bracket etc that I can use to hold the two Jerry Cans. But all I have seen is wilderness racks etc... that have mounts for the cans. Is there anything else that is nice and inexpensive that will allow me to safely mount the two cans to my Jeep. Thanks.. [ myuserid ]
#2 |
Been looking for the same thing myself, no luck as of yet.
2002 Jeep TJ SE 2.5L Sienna Pearl, dual tops, tan interior, 31x10.5's, 1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know) Work 2 Live, Live 2 Play, Play = JEEP |
#3 |
i wear foil underwear too
i don't think there's much as far as "inexpensive" goes. I've gone as far as asking the fabshop forum boys about anything they might have... but nuthin.
time to step up PSC! lj
ಠ_ಠ |
#4 |
Do you wheel more than 1 or 2 days at a time? I start out with a full tank, wheel about 8 hours, and still have well over a 1/2 tank of gas. I use my Jerry Can for the mower and quad now.....
2001 TJ Sport Everything SELF INSTALLED. The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more ! |
#5 | |
Need a better solution.
#6 | |
I also like to be prepared. To a fault according to my girlfriend. lj
ಠ_ಠ |
#7 |
DAJC.......Get stuck!!!!
I saw someone had a fabbed up tire carrier that had a couple of gas can's between the tire and the tailgate, but it was pretty expensive. I will try to find it. When I build (or get a friend to) a tire carrier I am going to incorporate the same sort of thing, I jsut don't see room for them beside the tire. Hopefully someone finds something and shares the word, AL
"rejected by the signature police" |
#8 |
whatever you end up doing, keep it outside the vehicle. fuel and passengers dont mix. just sticking a can inside is easy but dangerous.
www.pavementsucks.com http://www.cardomain.com/member_pages/view_page.pl?page_id=842234 |
#9 |
http://www.stevesjeepfab.com/products.htm
The bumper/carrier at the bottom of that page carries 2 cans. It's kinda expensive but is worth it imo. Later
'87 Grand Wagoneer '80 CJ7 |
#10 |
Bungee a 5 gallon plastic can to your rear bumper.
I've ot a hi-lift mounted back there and it works perfectly. It's like a sill, and I use a pair of big bungee's across it. When I get to the trails I usually set up camp first, so off comes the can. -Just and idea. --BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill. |
#11 | |
Running out of gas means you're having more fun than me ! ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
