Jerking at 45mph - JeepForum.com
post #1 of 2 Old 04-29-2013, 03:19 PM Thread Starter
rheavner
Jerking at 45mph
I have a 99 TJ with a 2.5L and 3 Speed Automatic. 32rh I believe. When going down the road and the converter is in lockup the jeep will jerk at 45mph on any kind of incline. Never at 40 and never at 50 but always at 45mph. It's driven me nuts to the point that I mounted a switch inside that I can hit to turn off the lockup solenoid. If I get on the gas and keep it from shifting into lockup until past 45mph it's fine until I slow to 45mph. It seems my problem would go away if I could install something that would automatically keep it from going in to lockup at less than 50mph. Is there anything that will accomplish that? My wife drives it quite a bit and I don't like leaving the solenoid bypassed all the time as I'm worried about the transmission heating up. Any help much appreciated.
rheavner is offline
post #2 of 2 Old 04-29-2013, 04:45 PM
tjmdr
I have found that using synthetic transmission fluid cures that problem. If you are holding the same speed or under light acceleration and it shutters lightly, but quits when you are under heavy acceleration , I have found this to cure the problem. Just my experience . I hope this helps.
It's not how many miles per gallon it gets, It's how much fun per mile!!
tjmdr is offline
converter , solenoid , torque converter , transmission
