Jerking 1-4th gears - JeepForum.com
post #1 of 15 Old 04-29-2012, 03:32 PM Thread Starter
Patman8354
Jerking 1-4th gears
I purchased a 99 TJ 4.0L 5 mt with 60k mi yesterday and thought I was getting a great deal. Until late last night when it started bucking violently front to back while I was driving. It doesn't always do it. It usually starts out with a few small jerks and then a strong increase until I push the clutch in and start again. It also has an intermittent rough idle. I know it just had a new distributor cap and rotor, plugs,wires, and steering box installed if that helps. Does anyone have any experience with this? I really hope it is nothing expensive.
Patman8354 is offline
post #2 of 15 Old 04-29-2012, 05:24 PM
Jeepsr4me
Sounds like a CPS issue. I went to buy a wrangler a few years ago. I get there and test drive it, and it started what you describe. The guy said it only did it every now and again and was embrassed about it. I got it for 1000 less than his bottom dollar, drove straight to autozone and replaced the cps in their parking lot. Drove home perfectly never did it again..
Jeepsr4me is offline
post #3 of 15 Old 04-29-2012, 05:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
CPS? Or do you mean TPS?
Typically, a CPS will either function perfectly or not at all, while a TPS will most definitely cause a driveability issue.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 15 Old 04-29-2012, 05:55 PM
Jeepsr4me
CPS.. I do know what is what. Fluke that I changed it, cause thats all autozone had in stock and I said might as well. The old one was over 140k miles on it.
Great write up here. http://www.4x4xplor.com/cps.htm
For me, my Jeep wasn't throwing any codes and so I wasn't completely sure that this was something I needed to replace. What lead me to think that it may need to go was the fact that I now have over 120,000 miles on the odometer, I have already replaced my O2 sensors and still had various engine issues including a rough idle under specific conditions. Specifically, my engine would run very rough on cold mornings or after driving it a long time with the AC on, turning off the engine briefly and then starting it back up again. I had also experienced times when climbing up long highway hills the engine would run quite rough... almost as if it were misfiring. Now, I should tell you that things are better since installing a new CPS but my engine is still running far from perfect.
Anyway, this write-up should help you out if replacing your Crankshaft Position Sensor is something that you need to do.
post #5 of 15 Old 04-29-2012, 06:21 PM Thread Starter
Patman8354
Jeepsr4me- Were you throwing a code/CEL? Mean Max- Are the CPS and TPS easily accessed? If so I will probably just do them both.
post #6 of 15 Old 04-29-2012, 06:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Patman8354
Jeepsr4me- Were you throwing a code/CEL? Mad Max- Are the CPS and TPS easily accessed? If so I will probably just do them both.
Yes, they are easily accessible.
The CPS is located on the bellhousing, at about the 11 o'clock position if you were looking at the rear of the engine. It can be changed from top or bottom.
The TPS is located on the throttle body assembly. It can be changed by removing two small Torx head screws.
Max
Mean Max is offline
post #7 of 15 Old 04-29-2012, 06:37 PM Thread Starter
Patman8354
Ok. I think I am going to start with the TPS because it is the more inexpensive of the 2 parts. Is this something that I need to go to Jeep for or are the aftermarket parts just as good? Thank you so much. As this is my first Jeep I think I will need all the help I can get.
post #8 of 15 Old 04-29-2012, 06:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I use locally available parts from the parts store.
TPS
CPS
Max
Mean Max is offline
post #9 of 15 Old 04-29-2012, 06:49 PM Thread Starter
Patman8354
Thanks! I will let you know how it turns out tomorrow. All of my local parts stores are closed now.
post #10 of 15 Old 04-29-2012, 07:06 PM
Jeepsr4me
That write up I posted the link to has pics and everything. Look for a vacuum leak 1st. I am a pretty good auto mech so I take into account that all the little things have been done or I do them. Vacuum leak will cause issues, also bad plugs and wires and cap. Seen bad straight out of box. I test them BEFORE putting in. Easy to do with volt meter.
post #11 of 15 Old 04-29-2012, 10:33 PM Thread Starter
Patman8354
How much resistance am I looking for with a good sensor?
post #12 of 15 Old 05-01-2012, 04:31 PM Thread Starter
Patman8354
It looks like the TPS was in fact the issue. I replaced it and threw it on a scanner while I drove around and all the numbers looked good. Thanks for all of your help guys!
post #13 of 15 Old 05-02-2012, 02:24 PM Thread Starter
Patman8354
So now instead of doing it all the time randomly it just does it when its cold now. Is the CPS the next part I should check?
post #14 of 15 Old 06-22-2012, 04:55 AM
johnxjeep
It seems there are a lot of threads on this problem/subject so I will post to the latest one.
My jeep started acting this way so I replaced the TPS low and behold that did nothing to stop the jeep from behaving badley like this.( she is still acting like a spoiled brat)
Has anyone actually fixed the problem? The posts/threads I have read have not really found a solution for the issue.
Any thoughts ?
Thanks.
johnxjeep is offline
post #15 of 15 Old 06-22-2012, 08:51 AM Thread Starter
Patman8354
I am starting to think it is a possible idle air control motor. I will do more research this weekend probably.
bucking , jerking
Jeep is jerking J-B TJ Wrangler Technical Forum 10 02-18-2012 04:14 PM
Jerking suspension mclanejm1 TJ Wrangler Technical Forum 0 01-06-2012 08:35 AM
jerking at low RPM dyna TJ Wrangler Technical Forum 7 07-18-2011 11:05 AM
Tj jerking at 30km/m don't know what could be wrong DaltonGareau TJ Wrangler Technical Forum 1 06-03-2011 06:52 PM
The Jeep Jerking Bubba3200 TJ Wrangler Technical Forum 11 06-24-2009 07:51 PM
