Jeeptubes DIY Tube Fender Install
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I have been looking at tube fenders for awhile now, and saw jeeptubes.com was selling a DIY tube fender kit for $80, so I figured I'd give it a try.
For $80, you get some pre-bent tubes and it's up to you to fabricate the rest.. ![]() I did some research on the internet and got a basic idea of what I needed to cut off the existing fenders. I started by removing the OEM plastic fender flares and then removed the bolts attaching the fender. ![]() I set the top tube on the fender and traced an approx outline, so I knew about where to cut off the top of the fender. I started trimming the sheet metal from the fender. ![]() With the sheet metal out of the way, I had to start thinking about how to attach the top tube to the jeep. For the rear I decided on some angle iron I had laying around. I measured the mounting holes and drilled out 4 on each. ![]() On the jeep ![]() A test fitting of the upper tube, looks like I will have to do a little grinding on the tube to keep things flush.. ![]() With that in place, I started creating the fron upper mount. I had some thin metal laying around the garage, but wanted something stronger.. I decided to cut 2 rectangle pieces out of some square tube I had laying around. ![]() I am leaving a little bit of the 90 degree edge on the metal for strength. To create the curve I added some cuts to the side of the metal so i could bend it easier. I plan to weld this up later. ![]()
#2 |
I'm looking forward to seeing this come together. Some kind of flat fender is in my future to open things up for 35's without adding any more lift than what I currently have. Are you going to open the back side of the fender well to avoid rubbing at full turn-n-stuff?
'06 Solar Yellow Rubicon Unlimited -- The Big Yellow Brick Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy |
#3 |
Crawled
#4 |
Fool Injected
And now, tonight's feature presentation......
My build: http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/ |
#5 |
#6 |
Hired Yeti-Basher
Sweet! Make with more pics!
If it's worth doing, then it's worth overdoing. Jeeps are like strippers...they should be topless as often as possible. |
#7 | |
I didn't get much done last night due to son's baseball game.. i decided to remove the lip I left earlier on the front mount (It just didn't look right) I then measured and drilled the 3 holes and attached it to the Jeep. ![]() With the 2 mounts in place, tonight I should be able to tack the upper tube in place. Looks like I will have to shorten the top tube just a bit. ![]() |
#8 |
I was able to make the drivers side upper mount last night..
![]() Then I leveled and tacked in the back. ![]() and the front ![]() Did the same for the drivers side. ![]() Now I am ready trim part of the battery tray to try and gain some extra clearance for the new wheel opening. I plan on attacking that tonight. I am also planning on trimming the top part of the fenders more and replacing it with new sheet metal. |
#9 |
Hired Yeti-Basher
Very cool.
#10 |
Looks great! How do you plan on doing the notches? You should practice with with some scrap first until you get the hang of it. Unless you've done it before. Good luck.
Lowered, Dubbed, and Spinning Why wear a flip flop on your left foot, and a steel toe on the right? |
#11 |
Fool Injected
Those fender cuts look pretty rough, how are you gonna fix that? And it could be just the pic but the passenger side looks like you cut off too much of the fender and left a gap between the fender and the tube.
#12 |
looks pretty sweet!
Jamison IBEW Proud 1994 YJ Crawler Project 2005 Dodge Ram Cummins Tow Rig 2000 XJ Build Done Right... (Build Thread) SOLD 2005 TJ Budget Build (Build Thread) TOTALED |
#13 |
Hired Yeti-Basher
I think that he's already planning on fixing the over-trimmed metal.
#14 | |
I also ended up cutting away part of the lower battery box for added clearance. I then reinforced the battery box and reattached the battery tray. (I will try to get some pics of that if any one is interested. I did the same for the drivers side. Last night I got the second tube welded in on each side. (It did take a bit to get it notched correctly) ![]() ![]() ![]() I then removed them from the Jeep and finished all the welds. I hope tonight to get some of the new sheet metal in place. |
#15 |
looking good! can't wait to see the finished product
2002 Black Sahara |
| Tags |
| jeep tubes, jeeptubes, diy, tube, fenders, install |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
