Jeep Wrangler TJ 4.0L Horrible Clunking Noise. Includes Video - Page 2 - JeepForum.com
post #16 of 36 Old 12-05-2012, 11:51 PM
jbmolly
Originally Posted by sduncan View Post
It seemed to me that is was worse when turning. Pull the cover off and look at the spider gears..I'd almost bet one is bad.
X2,
Check the spider gears. I had this problem on the D30 in my XJ last year. I grenaded the spider gears in it. it got so bad that it would lock one side and make the jeep jerk to the left or right depending on which axle it locked up.
Bone Stock 1993 Grand Cherokee Laredo
Here we go again, Getting ready to start my next project
jbmolly is offline
post #17 of 36 Old 12-06-2012, 10:16 PM
joe108
try putting it up on jacks, ****with proper safety precautions of course****, run it and see if it still makes the noise, if its quiet then start looking at the suspension as mentioned
joe108 is offline
post #18 of 36 Old 12-07-2012, 01:23 PM Thread Starter
JustinJeep40
I will post a follow up video in the next few minutes (once youtube finishes uploading) with the jeep up on jacks (cinderblocks because someone stole my jacks ) and its funny, the jeep seems to sound fine when its running and even if i give it a little gas. but as soon as i hit the brakes it starts jumping, however as you can see in the first video this is not the case when i am driving normally.
JustinJeep40 is offline
post #19 of 36 Old 12-07-2012, 01:36 PM Thread Starter
JustinJeep40
post #20 of 36 Old 12-07-2012, 03:09 PM
Mboelts
Sounds like shocks or maybe Track bar
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline
post #21 of 36 Old 12-07-2012, 05:18 PM
NE4X4
What was the diff. oil like when you pulled the cover? If the diff. is the problem the oil should have had at least very fine metal fillings in it making the oil sparkle or it could have chunks of metal in it. My guess is that you either have a trashed diff. (spider gears) or possibly a broken axle shaft. The reason that applying the brakes makes the noise could be because one brake either left or right will contact first or harder than the other making the spider gears turn as if you are cornering slightly. I don't know if you understand how a diff. works, but my bet is the diff. is bad, but that is major work so be sure to check everything else that is easy to fix first.
NE4X4 is offline
post #22 of 36 Old 12-07-2012, 05:26 PM Thread Starter
JustinJeep40
I haven't pulled the cover off the diff yet but if I did trash the differential ill probably just go to a junk yard and pull the whole differential off of a TJ that'll probably be cheaper then buying all brand new gears and paying someone to put them in when I can just change the whole did myself. But if its just my spiders I'll just replace them. The pinion gear is my deciding factor at this point. If its junk, the whole differential is getting replaced
post #23 of 36 Old 12-07-2012, 05:43 PM
Skyryder
Busted tooth/teeth. Either ring & pinion or spiders. It's just about ready to grenade!
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #24 of 36 Old 12-07-2012, 09:25 PM
Red02TJ
what does the noise do as you speed up or slow down? does the frequency of the noise change with speed? i had a broken pinion tooth and the noise got worse as speed increased. your noise doesn't seem constant, so i'm guessing it's not the diff. any movement of the axles sideways? do you know if there is a locker installed? it kind of sounds like a locker that disengages when you turn. maybe there's a locker installed and needs a spring replacement. i hope this helps.
Red02TJ is offline
post #25 of 36 Old 12-09-2012, 07:19 PM Thread Starter
JustinJeep40
I took it to the jeep dealership around my way yesterday, I was going to try to do it all myself but I don't have the time to work on it, thanks for all the help and I'll let you guys know everything that happened.
post #26 of 36 Old 12-09-2012, 07:36 PM
oakmckinley
When my rear went, it made a buzzing/rubbing sound like loud tires (too bad I thought it was my tires so I disregarded it for months), and when it finally went it was LOUD, I barely made it 10 blocks home. I mean embarrasing loud, like you'd go to the window too see what the racket was. That last block I had to run in 4wd to make it, the rear was completely gone.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #27 of 36 Old 12-09-2012, 09:39 PM
_KONG_
You should have just pulled the cover to begin with. You didnt know the last time the fluid was changed so should change it anyways. You could have checked the diff and did maintenance at the same time
_KONG_ is offline
post #28 of 36 Old 03-19-2013, 12:11 PM
millcat72
Hey what ended up being the issue? My 02 has started making the exact same sound. I have replaced sway bar links and bushings, lower control arms and bushings, rear shocks and rear drive shaft u-joints. Mine isn't as loud as yours but still the same sound. Before I take it somewhere I want an idea if it is something that I can do.
millcat72 is offline
post #29 of 36 Old 03-19-2013, 02:09 PM
tjstevo
mine locks up and binds wen turning or shifting or letting out the clutch its so noisie
tjstevo is offline
post #30 of 36 Old 03-19-2013, 02:14 PM
tjstevo
i want to replace the inner with arb lockers
but what is causing the binding i get it front and rear
tjstevo is offline
loud , noise , rear diff , rear differential , transfer case
