Jeep Wrangler TJ 4.0L Horrible Clunking Noise. Includes Video - JeepForum.com
post #1 of 36 Old 12-05-2012, 04:49 AM Thread Starter
JustinJeep40
So starting yesterday(12/3/12) My jeep has been making this horrible noise coming from the rear. It started out very subtle but as today progressed it became worse and worse and eventually was jerking my jeep back and forth down the entire road. Im new to this forum so be kind if I'm being a complete idiot. any feedback is appreciated i just do not want to spend a couple grand trying to fix something thats not even broken!
Here is a video to help explain things a little bit more:
Thanks for helping me while I'm freaking out about it
JustinJeep40 is offline
post #2 of 36 Old 12-05-2012, 04:56 AM Thread Starter
JustinJeep40
I forgot to also add that My rear diff has started leaking gear oil, i don't know if thats a gasket failure or what. but it'll make it a whole lot easier if i have to replace the gasket anyway. just because that another reason to look in there lol.
post #3 of 36 Old 12-05-2012, 06:41 AM
troy.j
good call on pulling the cover and not driving it. post a pick whin you get it apart.
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
post #4 of 36 Old 12-05-2012, 02:16 PM
Mboelts
Also check the shocks and the track bar.
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline
post #5 of 36 Old 12-05-2012, 02:21 PM
afusco1222
Sounds like a bushing of some sort has failed. I would check the control arms as well as ^^^^^^
afusco1222 is offline
post #6 of 36 Old 12-05-2012, 04:52 PM
Domgod
Sounds like a bushing. If it were in the diff it would be a more constant noise i would think. prybar all you bushings in the rear to see for any movement.
If it ain't broke, don't fix it!
Domgod is offline
post #7 of 36 Old 12-05-2012, 05:03 PM
dmblair
Really sounds like it suspension related like the others have mentioned. Have you noticed it does it only going over bumps or in pot holes or anything of that nature?
dmblair is offline
post #8 of 36 Old 12-05-2012, 05:21 PM Thread Starter
JustinJeep40
It does it all the time, when it started it was only when I went around turns. But as the day progressed and I drove it more it just got worse. I could be wrong, but it seems to jerk the entire jeep around and it's really vigorous. That's why I thought maybe one of the gears in the diff is stripped almost completely besides a couple teeth and it skips and catches again causing the clunking and the jerking. Although I just ordered a new rear sway bar and endlinks because the sway bar in the back was loose to the point where I could take the sway bar and move it back and forth in the bushings.. Do you think that could be the problem? I ordered the sway bar before the problem started.
post #9 of 36 Old 12-05-2012, 07:37 PM
Mboelts
Try going out and just rock the jeep back and forth. If you hear it then its the suspension. If not its drivetrain related.
KCCO!
Mboelts is offline
post #10 of 36 Old 12-05-2012, 07:51 PM Thread Starter
JustinJeep40
Just went out and jumped on each side of the back bumper. I just replaced the shocks not even a month ago. An haven't had tags for more than a little over two weeks. I've only put about 600 miles on it since I've had it and it has about 98000 on it all together. I'm guessing the previous owner never changed the gear oil in the differential throughout its lifetime. But regardless I'll be sure to post some pics of the carnage (if any at all) in the differential. If not its on to the transfer case, by I've only driven in 4wd 2 times at the most since I've gotten the jeep and haven't done any serious mudding just a few puddles, also I've always made sure I've returned to 2wd before getting on pavement. The clunking is just as bad when in 4wd but I wouldn't say it's any worse than when in 2wd so I'm imagining maybe I broke some teeth on a spider gear or two and I sure hope that's it because the last thing I want to do is try to take out the pinion.
post #11 of 36 Old 12-05-2012, 07:53 PM
Mboelts
Before you pull the whole diff apart check the drive shaft.
KCCO!
Mboelts is offline
post #12 of 36 Old 12-05-2012, 07:55 PM Thread Starter
JustinJeep40
I went out and twisted the drive shaft with my hand a little because at first I though I just had bad U-joints. The drive shaft seemed fine with as much movement in it as you would expect a driveshaft to have. Also the U-joints looked to be fine as well.
post #13 of 36 Old 12-05-2012, 07:58 PM
skip11and1
2013 MK Patriot
is it stuck in 4 wheel drive?
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #14 of 36 Old 12-05-2012, 07:59 PM Thread Starter
JustinJeep40
No, the dash does not indicate 4wd and it does not feel nearly "torquey" enough to be in 4wd. I'm 99% she's in 2wd.
post #15 of 36 Old 12-05-2012, 08:57 PM
sduncan
sduncan's Avatar
It seemed to me that is was worse when turning. Pull the cover off and look at the spider gears..I'd almost bet one is bad.
'98 TJ, 5.7 HEMI,
sduncan is offline
loud , noise , rear diff , rear differential , transfer case
