Jeep won't stop overheating and burning coolant - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep won't stop overheating and burning coolant
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 07-16-2010, 06:32 PM   #1
tjoffroader
My '02 TJ (six cylinder) will not stop burning coolant. It's getting to the point that it's burning off a topped off radiator's full of coolant nearly everyday.
Any ideas on what I can start checking to find out what I need to fix/replace?
tjoffroader is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 06:36 PM   #2
freeskier93
Blown head gasket. Good luck finding a replacement gasket with that V-6 you have.
Look at your oil, is it milky like a shake? Any puddles? No way a weeping hole could make you lose that much coolant.
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 06:36 PM   #3
jebmccall
1997 XJ Cherokee
its an inline 6, and if its burning coolant you have a blown head gasket and will have to take it to a shop to get it repaired. are you seeing white smoke form the exhaust pipe? is youre oil milky? these are signs of a blown head gasket.
jebmccall is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 06:53 PM   #4
NakedJeeper
What makes you say it's "Burning coolant"? Have you pressure tested for coolant leaks?
NakedJeeper is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 07:57 PM   #5
DevilDogDoc
Location: Yucca Valley 20 miles from Johnson Valley, CA
Yeah it'll stop doing that soon enough...
An ugly Jeep with some stuff.
DevilDogDoc is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 08:36 PM   #6
2kbeep
Do a pressure test before jumping on the wagon of the blown head gasket. We need the whole story. Did you replace anything recently? Water pump, radiator, radiator fluid, thermostat?
2kbeep is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 08:52 PM   #7
freeskier93
What else could it be that would make the OP lose that much coolant? If it were a leak it would be noticeable, so there's really only one more option. Nevertheless, a pressure test wouldn't be a bad idea.
coolant , leak , over heating
