Jeep Won't Start (Clicking Sound) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep Won't Start (Clicking Sound)
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 01-25-2011, 01:09 PM   #1
Gantt
Jeep won't start and there is a clicking sound.
I turn the key and it makes the clicking sound while it is turned to the "on" position. The the gauges will shoot up and the it will tell me how much gas I have. But all other gauges will fall. Also, the radio will not stay on.
Also, the "Check Engine" light will flash briefly then stay on. The "Check Gauges" light will stay on as well.
Is this as simple as the battery needs to be changed?
Looking forward to your answers.
Gantt
Gantt is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:12 PM   #2
Erik T.
Sounds similar to the problem I had when my CPS went out. (Crankshaft Position Sensor).
Easy fix, cheap part.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:14 PM   #3
JBTJ
Bad battery, Extream heat and cold are very hard on batteries.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:14 PM   #4
teesh
Tried jumping it yet? Sounds like dead battery.
What kind of Jeep?
teesh is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:15 PM   #5
Noxian
2011 JK Wrangler
First, check your battery cables, loose battery cable can do this, try tightening and cleaning them.
Also
Mine did that when the TPS (throttle position sensor went bad)
Also
When the battery was bad too.
Noxian is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:19 PM   #6
Gantt
I figured it was the battery.
I changed my Throttle Position Sensor about two or three months ago. The battery cables seem fine. I will try jumping it off and if that doesn't work I will look into the Crankshaft Position Sensor.
Anyone have good directions on how to change the CPS out?
Gantt
Unread 01-25-2011, 01:26 PM   #7
Noxian
2011 JK Wrangler
Gantt
When you say the battery cables seem fine, did you just visually inspect them?
Mine became loose this summer and they were tight if checked by hand however they still wouldn't start the jeep, measuring using a multimeter showed resistance between the cable and the post.
I had to actually take the cables off put them back on and tighten.
Unread 01-25-2011, 01:29 PM   #8
Gantt
I inspected them by hand. I figured the battery is most likely dead. After I made the original post I remembered it coming close to dying almost a year ago. Not sure how it even lasted this long. I will try to take them off though. I love to save as much money as possible.
BTW for the poster that asked. It is a 2003 TJ. Nothing special, but I will never get rid of it.
Unread 01-25-2011, 01:30 PM   #9
Gantt
Unread 01-25-2011, 01:33 PM   #10
champelite210
Mine started doing this but I knew the battery was good. Terminals at the battery were tight. checked the connections at the starter. Seemed tight but corroded. Took them loose cleaned them up and now starts everytime.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:37 PM   #11
finsout
This is exactly what happened to me a few days ago. Try to get someone to start it while you move the positive terminal. mine fired right up. I tightened everything and haven't had the problem since.
finsout is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 01:37 PM   #12
JBTJ
Gantt
Dude, how can it be the CPS if it won't even turn over. Think about it.
Unread 01-25-2011, 02:02 PM   #13
Gantt
No clue, I am not expert on this. But, thanks to the help of everyone at JeepForum I usually can fix the problems. Someone mentioned that the CPS could be the problem earlier in the thread.
Gantt
Unread 01-25-2011, 02:09 PM   #14
JBTJ
Gantt
It's you battery.!!!!
Unread 01-25-2011, 05:01 PM   #15
Erik T.
That's my fault, I was thinking the CPS when I meant TPS.
-Erik.
