Jeep wont start - Checked the vitals - JeepForum.com
post #1 of 8 Old 11-16-2010, 10:01 PM Thread Starter
TJftw
This is really weird:
My jeeps charge indicator went to zero while i was a few blocks from my house so I drove home right away and shut her down.
-Battery shows 12.4V
-Just tested the alternator the day before when i cleaned the terminals and its putting out 14.5V
-There is a good connection between the battery and alternator I tested with a voltmeter.
-I've removed my winch/lights/sub cables to simplify everything
-When I try to crank it all i get is the solenoid clicking
-When I hooked up a spare battery to jumper it, the motor turns over but not super fast. It should still be enough to start though. With the additional battery im getting just under 13V. Even though it turns over, it doesn't want to start!
What is wrong with my reasoning here? This just doesn't make sense to me. The next thing I will test is if I get sparks at the cylinders. If you guys can solve my problem, I promise to finally get a membership! I've been meaning to for a while now.
Black Jeep Society Member #398
*Jeep Wave*
TJftw is offline
post #2 of 8 Old 11-17-2010, 10:43 AM Thread Starter
TJftw
bump :S
*Jeep Wave*
TJftw is offline
post #3 of 8 Old 11-17-2010, 11:41 AM
TXjeepTJ
TXjeepTJ's Avatar
Clean your battery terminals/connectors scrape them up real good exposing new surface,make sure they are on real tight. Let me know what happens
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #4 of 8 Old 11-17-2010, 01:53 PM
jabroni3411
With any starting problems i always check the 3 main causes, battery alternator and starter. i say you've got 2 out of 3 down try checking the starter. could be sticking causing the jeep to turn over slow or not turn over at all. also the connections to the starter, could be oxidized and not getting a strong connection from the battery.
Check My Build
jabroni3411 is offline
post #5 of 8 Old 11-18-2010, 09:21 PM Thread Starter
TJftw
Thanks, ive checked all 3, and they look good. I charged the battery again tonight and it magically fired up! It's showing charging, but it still worries me because I didnt actually do anything haha. Ill keep an eye on it for now, and plan on getting a new battery soon.
*Jeep Wave*
TJftw is offline
post #6 of 8 Old 11-20-2010, 07:16 PM
wushaw
Rockin jeep
wushaw's Avatar
You could very well have a low cell in the battery, it will show good voltage till you put a load on it then it falls on its face.
Also when you check your battery terminals, "looks good" don't always mean it is, cleaning them is the only way to remove any clear oxidation.
wushaw is offline
post #7 of 8 Old 11-21-2010, 04:02 PM Thread Starter
TJftw
Thanks for your responses so far. I've tried another battery and same problem. Right now it works perfectly one day, starts up fine, runs great etc. but then i'll be out somewhere and the battery meter will go to zero. If I leave the vehicle running its fine which leads me to believe that the alternator is running it fine, but after the vehicle is turned off, it wont start again. So if battery is fine, and alternator is fine, all it could be is the wiring, but i've cleaned the terminals like 3 times!! Could this be an ECU problem!?
*Jeep Wave*
TJftw is offline
post #8 of 8 Old 11-21-2010, 05:07 PM
wushaw
Rockin jeep
wushaw's Avatar
The alternator is regulated by the ECM, you could clean the ECM connectors and see if that helps.
wushaw is offline
alternator problem , electrical issue , start problems , wiring
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 05:57 AM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
Help....jeep wont start bbredstang TJ Wrangler Technical Forum 7 05-17-2006 08:56 PM
my jeep wont start DGoodman111 YJ Wrangler Technical Forum 6 06-21-2005 09:37 AM
Jeep won’t start. Checked these so far. Anything else you can suggest? TJSilverSport02 TJ Wrangler Technical Forum 6 07-29-2003 12:40 AM
