Jeep won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep won't start
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 01-21-2014, 10:38 PM   #1
Bologna
Jeep won't start, no click - nothing
I just replaced the power steering pump yesterday and drove for at least an hour on my jeep back to my house - so that should have nothing to do with this, but I figured I would mention it.
When I try to start my Jeep, nothing happens. No click or anything.
What I've done so far:
I checked the battery voltage and it read 12.5 volts
All my lights work and are not dim
My lights do not dim when I try to start it
I can hear my fuel pump
I checked the starter relay using an ohm meter and it read around 65 ohms on two tabs and 0 on the other two tabs, so it's good -- I also just tried using a new relay and it didn't fix the problem either
I then put the dmm in the starter relay slot in my fuse box and got a 12 volt reading from pin number 30
I did the same thing as above but put my key to the on position and got a 12 volt reading from pin number 30, 85, and 87
I just tried putting a fuse (20amp) in the #20 slot behind my glove box (which should bypass the clutch safety switch, i believe) and that didn't work either.
I took my steering column panel off and turned my key to the on position and then removed the key's lock cylinder and tried to start it with a screwdriver and that didn't work either.
I tried hitting my starter and solenoid with a screw driver - no luck
On my starter there appears to be 3 bolts. I attached a jumper cable from the top left one to the positive battery terminal and nothing happend. I then attached the jumper cable to the bottom left one to the positive battery terminal and all I saw was some sparks but not very much. I did not connect it to the far right one because it looks like a ground, but I can see the red positive wire going to one of two (or both) of the studs on the left. I can't tell which one because of the black plastic cover it has on it.
Here is a picture of my starter so you can tell what I mean by 3 studs. (In the pic you can only see one of the left, there are two - vertically)
Anyone have any other ideas? I've literally tried everything that I have found on-line. If you want pictures, I will gladly post some. I'm completely stumped on this. It ran perfect yesterday.
1998 TJ Wrangler - 197,000 Miles - Daily Driver
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline   Reply With Quote Quick reply to this message
Unread 01-21-2014, 10:47 PM   #2
TJ-Tera
Not sure how/what you did exactly with the ignition cylinder, but I had a similar issue with my Jeep awhile ago and the cylinder internals had broken and thus would not let the Jeep start. Perhaps there is a mechanic near you that you could take your ignition cylinder to and have it inspected?
TJ-Tera is offline   Reply With Quote Quick reply to this message
Unread 01-21-2014, 10:50 PM   #3
Bologna
But I took that whole cylinder(The one the key goes into) out of my Jeep and used a screwdriver instead to start it, and it still didn't work. So that couldn't be the problem
All Stock
4.0 Inline 6
Manual Transmission
Unread 01-21-2014, 10:53 PM   #4
TJ-Tera
Well, like I said above I'm not sure what you did with the screwdriver exactly or where in the steering column since I wasn't there, so I can't say for sure that a screwdriver would even work. Have you successfully started a car this way before?
#checkeredpast
#carthief?
j/k
Unread 01-21-2014, 10:59 PM   #5
Bologna
#checkeredpast
#carthief?
j/k
If you take that cylinder out, then there is a little hole in the very back that a screwdriver can slide into, you then turn the screwdriver like you would your keys. It's like what you see in the movies sometimes - just no wires involved
All Stock
4.0 Inline 6
Manual Transmission
Unread 01-21-2014, 11:00 PM   #6
TJ-Tera
Interesting...I figured there was some way since we don't have PATS keys but I never knew for sure
Unread 01-22-2014, 12:38 AM   #7
Dave02TJ
Are you still working on this?
Dave02TJ is offline   Reply With Quote Quick reply to this message
Unread 01-22-2014, 12:41 AM   #8
Bologna
Yes sir
All Stock
4.0 Inline 6
Manual Transmission
Unread 01-22-2014, 12:42 AM   #9
Dave02TJ
Do you have an assistant to help turn the key while you check something?
Unread 01-22-2014, 12:44 AM   #10
Bologna
I do not, he just passed out. I have tried hitting the starter though.
I will have one tomorrow though, what's your idea?
All Stock
4.0 Inline 6
Manual Transmission
Unread 01-22-2014, 12:45 AM   #11
Dave02TJ
So obviously the big wire from the battery goes to the starter. Its under that black cover, it needs 12.6 volts or there abouts. There should be a small wire on the solenoid, when you turn the key the small wire will indicate 12 volts, would be easy to see with a test light.
Unread 01-22-2014, 12:46 AM   #12
Dave02TJ
so if the small wire indicates it is getting power, that is the signal that energizes the solenoid. Tells you the ignition switch is working .
Unread 01-22-2014, 12:47 AM   #13
Bologna
I could leave my key in the on position, and check that small wire with a dmm?
All Stock
4.0 Inline 6
Manual Transmission
Unread 01-22-2014, 12:47 AM   #14
Dave02TJ
you could jump the big red wire to little starter signal wire and that will also energize the solenoid and the starter should spin.
Unread 01-22-2014, 12:48 AM   #15
Dave02TJ
small wire only gets power when the key is turned.
starter , tj , volt , wrangler
