Jeep wont rev up. - JeepForum.com
post #1 of 21 Old 11-15-2010, 01:29 PM Thread Starter
Farmkid
Jeep wont rev up.
This morning on my way home my jeep started spittin and sputtern. Then it would clear up and start running normal again. It done this about 2 different times before it finally let me down. The engine will idle but misses, it wont rev up beyond about 2000 rpms. It wont even pull itself foward. I checked the codes and nothing pops up. When it idles it sounds like it it having trouble sucking air because the air box intake is very loud and doesn't sound normal.
Farmkid is offline
post #2 of 21 Old 11-15-2010, 01:35 PM
05TurboS2K
Check for spark by pulling the plugs one by one and cranking a little to test spark.
Next test for fuel, there's a nut on the fuel rail just remember its fairly high pressure.
Double check there's nothing causing it to starve for air, AND make sure the exhaust isn't clogged such as a CAT that's plugged.
I'd think you'd be throwing a code from most of these but stranger things have happened.
Anyone more knowledgeable care to chime in?
05TurboS2K is offline
post #3 of 21 Old 11-15-2010, 01:40 PM Thread Starter
Farmkid
I can assure it's not the cat as the previous owner handled that situation. This morning while I was waiting to get pulled home I tapped on the IAC while it was idling and it seemed to clear up and idle smooth for a couple of seconds but went right back to running rough.
Farmkid is offline
post #4 of 21 Old 11-15-2010, 01:59 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
When is the last time you did a complete tune up?I would check first cap and rotor,plugs,wires,cleaning the throttle body,air filter,etc.
GOLENJEEPTJ is offline
post #5 of 21 Old 11-15-2010, 02:01 PM
GOLENJEEPTJ
Sounds like a possible 02 sensor also.
post #6 of 21 Old 11-15-2010, 02:05 PM
j_niko
2009 JK Wrangler
Change dist cap and rotor. Possibly wires, but there would have to be more than one bad to make it do that, I would think.
Also, does it seem to do it worse when it is raining or there is moisture in the air?
2000 - Sahara
1997 - Sahara
j_niko is offline
post #7 of 21 Old 11-15-2010, 02:10 PM Thread Starter
Farmkid
I did a tune up about complete tune up about 3000 miles ago. Yes it was raining this morning. That crossed my mind this morning but couldn't figure it out.
Farmkid is offline
post #8 of 21 Old 11-15-2010, 02:15 PM
GOLENJEEPTJ
Does it react the same whether the engine is cold or warmed up.
post #9 of 21 Old 11-15-2010, 02:16 PM
GOLENJEEPTJ
What did your tune up consist of?Elaborate.
post #10 of 21 Old 11-15-2010, 02:27 PM Thread Starter
Farmkid
Plugs, wires, cap, rotor, air filter. It ran fine this morning until it got to normal temp. It was starting to rain this morning if that helps.
Farmkid is offline
post #11 of 21 Old 11-15-2010, 02:30 PM
j_niko
2009 JK Wrangler
I'll stick with dist cap
2000 - Sahara
1997 - Sahara
j_niko is offline
post #12 of 21 Old 11-15-2010, 03:25 PM
GOLENJEEPTJ
Try unplugging the upstream 02 sensor and see if it revs.
post #13 of 21 Old 11-15-2010, 04:13 PM Thread Starter
Farmkid
Got up this evening and went to crank it up. It ran perfect for about 20 seconds then went back to sounding like it only has 3cyl out of the 6 working
Farmkid is offline
post #14 of 21 Old 11-15-2010, 04:16 PM
slafferty
i say its a cat..
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #15 of 21 Old 11-15-2010, 04:45 PM Thread Starter
Farmkid
There is no cat.
Farmkid is offline
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 05:57 AM
jeep LJ auto to manual swap jeep wont fire?? g1tdrty69 TJ Wrangler Technical Forum 20 09-22-2010 01:36 PM
jeep wont come out of 4wd jimG16 TJ Wrangler Technical Forum 6 07-27-2008 05:38 PM
clutch wont engage and jeep wont fire natehate TJ Wrangler Technical Forum 4 04-19-2007 07:10 PM
jeep wont run 14psisupra YJ Wrangler Technical Forum 1 09-12-2006 12:41 AM
