Jeep won't idle after battery drain - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep won't idle after battery drain
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Jspec Suspension BLOW-OUT FEBRUARY ONLY!! HURRY UP!Income tax season is upon us. We got what u need
Unread 10-16-2009, 11:24 PM   #1
freeskier93
So here is the story. TWICE the battery was drained (as many of you may know it is very easy to leave your lights on). The first time it would at least click but the second time it was totally dead.
Now the Jeep won't idle. After trickle charging the battery for a good day it will at least start the Jeep and keep a charge. The only problem is it won't idle upon a cold start. The engine cranks and starts but instead of the RPMs falling and idling at 800, they just keep falling until the engine dies.
The catch is if I keep on the throttle, to keep the engine from dieing, after about 10 minuets or so it will eventually idle. I have noticed that it will idle as soon as the temp hits regular running temp. (210?)
Of course the simple answer is it could just be the battery (It is an eight year old Optima battery). Other then the battery, is there anything else that could be causing this problem? My guesses would be IAC and my dad's guess is it could be the auto choke. Any other guesses?
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 10-16-2009, 11:48 PM   #2
sublimemaze
um.... alternator
sublimemaze is offline   Reply With Quote Quick reply to this message
Unread 10-17-2009, 12:14 AM   #3
chief100psu
This is common - rev the engine over 3k for 3 minutes and it will idle fine or drive it down the highway for a bit. The ecu has some setting that get reset and it needs to relearn how to idle. I have had this happen to me a few times.
chief100psu is offline   Reply With Quote Quick reply to this message
Unread 10-17-2009, 01:10 AM   #4
trikebubble
Same thing happened to us after my Wife left the lights on and drained the battery. I boosted the battery and it seemed to have trouble idling for around 5 minutes. I replaced the old crap battery the next day and have had no issues since.
trikebubble is offline   Reply With Quote Quick reply to this message
Unread 10-17-2009, 01:49 AM   #5
xxiiiliv
X2...had the same problem...ended up being the battery, only a year old
xxiiiliv is offline   Reply With Quote Quick reply to this message
Unread 10-17-2009, 07:22 AM   #6
Neil F.
1. Chrysler vehicles will not run with a weak or bad battery, or if the voltage is off. It will start and run as long as you keep your foot in it. The PCM will shut it down as soon as you take you foot off.
2. If it is an Optima Red Top, it is not a deep discharge battery meaning, it is not designed to be drained (the yellow top is) The Red will be damaged and not recover if drained down.
3. An 8 year old battery no matter what the brand is past the expected life.
Neil F. is offline   Reply With Quote Quick reply to this message
Unread 10-17-2009, 09:43 AM   #7
freeskier93
Thanks for all the help guys. I figured it's would probably be the battery but just wanted to get more feedback. Today I will probably swap the battery with one from a different car to see if that's the problem. If so I guess I will be spending money on a new battery. I will definitely buy an Optima battery again, except the one with the yellow top because this def. won't be the last time the battery is drained because lights were left on.
Unread 10-17-2009, 09:47 AM   #8
acrijos
Same thing happened to me and it was my red top Optima. It finally went after 10 years of service
We don't stop playing because we grow old. We grow old because we stop playing.
acrijos is offline   Reply With Quote Quick reply to this message
Unread 10-17-2009, 09:56 AM   #9
cberrykix
Sounds like the alternator is working, probably just the battery. Most parts stores will test either for free.
You can do a simple check on the alternator yourself: With the engine running turn your headlights on. When you rev the engine the lights should get a little brighter, dim a bit at idle. If this happens, the alternator is producing electricity. If you shut off the engine and the lights rapidly dim, then you can bet on the battery being the likely problem.
Like I said, most parts stores can test the alternator to make sure it is operating properly.
cberrykix is offline   Reply With Quote Quick reply to this message
