jeep wont crank after man to auto swap- need help - JeepForum.com
post #1 of 7 Old 07-12-2010, 11:19 AM Thread Starter
mcote1230
As the title I just completed a transmission swap from a AX15 to a 32RH. I went to start it yesterday and got to power to the starter in the "start" position. I have jumped the nuetral safety switch and still no luck.
It will start if i jump the two connections on the starter.
I was thinking it could be related to the ignition switch on the steering column??
Any ideas would be great!
this is a 97 4.0L sport
mcote1230 is offline
post #2 of 7 Old 07-12-2010, 04:05 PM
wushaw
Rockin jeep
wushaw's Avatar
Could be since the manual doesn't have a NSS or auto comp to worry about.
wushaw is offline
post #3 of 7 Old 07-12-2010, 04:33 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
need anything else for your swap? i just did the opposite of what you did.
Mail crawling.
MisfitSeven is offline
post #4 of 7 Old 07-12-2010, 05:01 PM
dodgetk81
I think you need to jump the clutch pedal switch, or I believe you can add a fuse to override that
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #5 of 7 Old 07-12-2010, 05:16 PM
wushaw
Rockin jeep
wushaw's Avatar
Or cut & splice.
wushaw is offline
post #6 of 7 Old 07-12-2010, 07:31 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
No fuse to add on a 97.
There is an auxiliary plug under the dash to bypass the clutch interlock...
Knuckelhead is offline
post #7 of 7 Old 07-13-2010, 05:53 AM Thread Starter
mcote1230
i'm all set guys! thanks for the help!
tj , wrangler , transmission , tranny , swap , start
jeep LJ auto to manual swap jeep wont fire?? g1tdrty69 TJ Wrangler Technical Forum 20 09-22-2010 01:36 PM
jeep wont crank- no dash power either tereck TJ Wrangler Technical Forum 5 01-06-2010 04:26 PM
2.5L Jeep wont start but will crank superslayer TJ Wrangler Technical Forum 9 05-30-2009 11:00 AM
Jeep wont crank/start Teddy TJ Wrangler Technical Forum 4 03-10-2009 02:08 PM
Help...Jeep wont crank asnbabyfce YJ Wrangler Technical Forum 5 08-08-2004 06:56 PM
