Jeep won't turn over on first try!! - JeepForum.com
post #1 of 4 Old 07-28-2008, 11:13 PM Thread Starter
mudslingertj24
My Jeep since I got it, has had troubles starting. It usually takes it two to three attempts for it to turn over.The starter is fine. I think this may have something to do with the sending unit or something like that. What needs to be looked at or tested to determine the problem. Any help much appreciated. Thanks....
mudslingertj24 is offline
post #2 of 4 Old 07-29-2008, 03:04 AM
Jeepguy1977
Jeepguy1977's Avatar
It sounds to me like the anti-drainback valve in your fuel pump is toast. A relatively common Jeep TJ malady. You'll probably need a new fuel pump, though I think some people have had other solutions. Here's a link to where you can find a guide on how to fix it.
http://www.stu-offroad.com/engine/fu...fuelpump-1.htm
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #3 of 4 Old 07-29-2008, 07:20 AM
kloppk
Try the following before starting your Jeep.
Turn the key from OFF to RUN, wait a couple of seconds, turn the key back to OFF.
Again turn the key from OFF to RUN, wait a couple of seconds, turn the key back to OFF.
Now start it. It ought to fire right up.
This should get you by until you have an opportunity to deal with the drain back valve issue.
kloppk is offline
post #4 of 4 Old 07-29-2008, 08:06 AM
ASUsax
I agree, fairly common problem. The post right after this will help, also.
Blue Jeep Club Member #197
'02 TJ - 33" BFG MT's's, some armor, yadda yadda. 2" BDS lift/1"BL
'94 ZJ - May it rest in pieces.
ASUsax is offline
Turn singal does not turn off when I turn left. MWguy101 YJ Wrangler Technical Forum 31 02-14-2010 04:21 PM
Jeep won't turn over Fenix85182 YJ Wrangler Technical Forum 5 11-25-2009 05:45 AM
Jeep won't turn over admisgd YJ Wrangler Technical Forum 1 10-25-2009 12:08 AM
jeep won't turn over robhalifax TJ Wrangler Technical Forum 3 10-10-2009 05:36 PM
Jeep will not turn over Gewehr43 TJ Wrangler Technical Forum 23 03-01-2009 06:48 PM
