Jeep won't turn over... - JeepForum.com
post #1 of 5 Old 01-23-2009, 07:22 PM Thread Starter
usetobejeeper
usetobejeeper's Avatar
Put a new battery in, still won't turn over. Light don't dim when trying to crank it.
Looking on-line it appears the solenoid and starter are one unit so I don't have to worry about one or the other? Is there any thing else that might keep it from cranking? Thanks
Show me a person who doesn't mind losing and I'll show you a loser.
usetobejeeper is offline
post #2 of 5 Old 01-23-2009, 07:25 PM
Giviner
Giviner's Avatar
If you are not getting any action check the connection at the starter. If that is all good check the voltage at the turn-on lead while someone else tries to crank it. If you get no voltage, then it's a wiring problem. If you have voltage, it's a starter problem.
2003 TJ Sahara
2010 WK
Giviner is offline
post #3 of 5 Old 01-23-2009, 07:40 PM
2jhanna
check both the starter end of the cable and the ground end.
jhanna
denton county, tx
2jhanna is offline
post #4 of 5 Old 08-16-2010, 10:30 PM
oneok
It sounds like a Crankshaft Position Sensor (CPS) The Jeep will not run or start if it is bad. This sensor is located on top of the bell housing (transmission), usually with one bolt, it sits inside the bell housing similar to a spark plug hole except, no threads just pressed into the hole. has a 12 inch electrical connection attached, cost $35-$45 and 15 minutes to change out very easy, they go out all the time. Google the part and you will find schematics and diagrams showing exact location. New sensor comes with a small pad attached to end of sensor, make sure pad is in place before you install it. Do not go to a repair shop, save your hard earned money, very easy to change. Change this sensor out before you think there is a problem with the fuel filter or fuel pump, they almost never fail on Jeeps, usually something simple like this sensor.
oneok is offline
post #5 of 5 Old 08-17-2010, 01:29 AM
wushaw
Rockin jeep
wushaw's Avatar
If your lights are dimming with the key in the start position that means amperage is being drawn from the battery like it should be but your engine is not turning over so.....remove your starter and take it to the parts house and have them test it. It sounds like your starter is shot to me.
wushaw is offline
Jeep won't turn off! Pitman99505 YJ Wrangler Technical Forum 24 11-15-2013 11:08 AM
Turn singal does not turn off when I turn left. MWguy101 YJ Wrangler Technical Forum 31 02-14-2010 04:21 PM
Jeep won't turn over Fenix85182 YJ Wrangler Technical Forum 5 11-25-2009 05:45 AM
jeep won't turn over robhalifax TJ Wrangler Technical Forum 3 10-10-2009 05:36 PM
jeep doesn't want to turn off :( Brack YJ Wrangler Technical Forum 8 01-21-2004 11:06 PM
