Jeep won't stop overheating and burning coolant - JeepForum.com
post #1 of 7 Old 07-16-2010, 07:32 PM Thread Starter
tjoffroader
My '02 TJ (six cylinder) will not stop burning coolant. It's getting to the point that it's burning off a topped off radiator's full of coolant nearly everyday.
Any ideas on what I can start checking to find out what I need to fix/replace?
tjoffroader is offline
post #2 of 7 Old 07-16-2010, 07:36 PM
freeskier93
Blown head gasket. Good luck finding a replacement gasket with that V-6 you have.
Look at your oil, is it milky like a shake? Any puddles? No way a weeping hole could make you lose that much coolant.
freeskier93 is online now
post #3 of 7 Old 07-16-2010, 07:36 PM
jebmccall
1997 XJ Cherokee
its an inline 6, and if its burning coolant you have a blown head gasket and will have to take it to a shop to get it repaired. are you seeing white smoke form the exhaust pipe? is youre oil milky? these are signs of a blown head gasket.
jebmccall is offline
post #4 of 7 Old 07-16-2010, 07:53 PM
NakedJeeper
NakedJeeper's Avatar
What makes you say it's "Burning coolant"? Have you pressure tested for coolant leaks?
NakedJeeper is offline
post #5 of 7 Old 07-16-2010, 08:57 PM
DevilDogDoc
Yeah it'll stop doing that soon enough...
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #6 of 7 Old 07-16-2010, 09:36 PM
2kbeep
Do a pressure test before jumping on the wagon of the blown head gasket. We need the whole story. Did you replace anything recently? Water pump, radiator, radiator fluid, thermostat?
2kbeep is offline
post #7 of 7 Old 07-16-2010, 09:52 PM
freeskier93
What else could it be that would make the OP lose that much coolant? If it were a leak it would be noticeable, so there's really only one more option. Nevertheless, a pressure test wouldn't be a bad idea.
coolant , leak , over heating
Stupid engine won't stop overheating!! treefiddyYJ YJ Wrangler Technical Forum 31 06-14-2012 11:54 AM
Burning Coolant :( sam24th YJ Wrangler Technical Forum 3 03-28-2010 09:23 PM
Jeep burning oil like no tomorrow?? Help! romanella YJ Wrangler Technical Forum 14 12-05-2007 12:40 PM
Cooling System knowledge - Coolant Antifreeze Overheating Thermostat Troubleshooting dragginwagon406 TJ Wrangler Technical Forum 8 03-31-2007 03:03 AM
I think the Jeep is Burning Oil ixl4 TJ Wrangler Technical Forum 6 08-19-2005 10:37 AM
