Jeep won't start...sometimes - JeepForum.com
post #1 of 8 Old 09-03-2011, 10:06 AM Thread Starter
MikeTheVike
Had the same problem one day last week that I had this morning. I would turn the key, starter would click once(can't remember 100% that it would click), the engine would not attempt to start or turn over. My gauges would go a little crazy initially and then my Check Gauges light would come on and my check engine light would blink. I can do this a few times and it will eventually start. The check engine light stays off.
I took it to the Auto Parts store to see if they could pull the last error code but it came up fine. Any ideas?
MikeTheVike is offline
post #2 of 8 Old 09-03-2011, 10:08 AM
-ShockWave-
Test the voltage going across the top of the battery to see if it is below spec. Or just go out and buy a battery. That is step one.
Could be ignition switch or starter related, once a battery has been swaped out and it continues to fail.
-ShockWave- is offline
post #3 of 8 Old 09-04-2011, 07:46 PM
hefightsfire
I've been having same problem lately. Tried cleaning the terminals and making sure everything was tight. It's done it once right after but not since. Got anything figured out for sure yet?
"The problem with quotes on the internet is that you never know if they are real."
Abraham Lincoln
hefightsfire is offline
post #4 of 8 Old 09-04-2011, 10:05 PM
joe108
jeeps don't like bad batteries that have poor voltage or connections, or ignition switch?
joe108 is offline
post #5 of 8 Old 09-07-2011, 06:06 PM Thread Starter
MikeTheVike
I cleaned the terminals, one was pretty crusty. So far so good...I'll update again if things start going bad again.
post #6 of 8 Old 09-07-2011, 06:37 PM
GlassCurtain
My fog light switch started to fail and would randomly turn my fog's on. After draining the battery and recharging a few times. I had the same issue with starting as you did. Not enough amps to crank. A new battery solved it. I hope just cleaning it was the solution. Let us know.
GlassCurtain is offline
post #7 of 8 Old 09-08-2011, 02:47 PM
oakmckinley
This just happened to my cherokee, wouldn't turn over just clicked. Dash kinda flickered, then the check gages came on. It was a failed Alt, which in turn fried my 3yr old battery.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #8 of 8 Old 09-08-2011, 04:46 PM
pyrow07
if this comes up again and you bought a battery or know that it does not need a battery, try hitting the starter while someone turns the jeep over, or hit it then turn it over, if that works then you need a new starter.
pyrow07 is offline
Jeep Wouldn't Start, Then Started, Now Won't Start - No Error Codes? drb TJ Wrangler Technical Forum 3 08-26-2011 12:50 AM
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 10:36 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
Wipers start when I start the jeep Rock & Roll TJ Wrangler Technical Forum 3 09-07-2005 10:12 PM
