Jeep won't start - Page 2 - JeepForum.com
post #16 of 48 Old 01-21-2014, 11:50 PM Thread Starter
Bologna
Originally Posted by Dave02TJ View Post
small wire only gets power when the key is turned.
So turned as in starting... I see now. I will for sure test that out tomorrow. So if it doesn't read 12 volts then my problem is the ignition switch?
1998 TJ Wrangler - 197,000 Miles - Daily Driver
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline
post #17 of 48 Old 01-21-2014, 11:50 PM
Dave02TJ
so basically, if you jump the small wire to the big red positive wire and it doesnt crank your starter is bad.
Dave02TJ is offline
post #18 of 48 Old 01-21-2014, 11:51 PM
Dave02TJ
right if the small wire does not indicate power when the key is turned, you will have to look at the signal side of things.
Dave02TJ is offline
post #19 of 48 Old 01-21-2014, 11:52 PM Thread Starter
Bologna
Well I can test that out by myself, with the key left in the on position. Correct?
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline
post #20 of 48 Old 01-21-2014, 11:53 PM
Dave02TJ
if the key is in the on position it will start and run. if in the off position it will crank. make sure you are in neutral.
Dave02TJ is offline
post #21 of 48 Old 01-21-2014, 11:56 PM Thread Starter
Bologna
Ok, I will do that right now. The only wire I have here is 10 foot jump cables though, so hopefully the clamps fit in that small space
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline
post #22 of 48 Old 01-21-2014, 11:58 PM
Dave02TJ
also bring a screwdriver, pop the cap off the positive cable at the starter and then you could probably jump it with a screwdriver.
Dave02TJ is offline
post #23 of 48 Old 01-22-2014, 12:09 AM Thread Starter
Bologna
I got nothing but very minimal sparks.
I did hear a sound every 10 seconds or so, it sounds like a cat scratching a couch. (This is when the key was in the on position and I was under the Jeep messing with the starter)
Just to make sure I did it right...
I tried to jump the top left one in this picture with the right one.
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline
post #24 of 48 Old 01-22-2014, 12:12 AM
Dave02TJ
no, one sec let me look at mine to see if what I want you to do is possible
Dave02TJ is offline
post #25 of 48 Old 01-22-2014, 12:13 AM Thread Starter
Bologna
Alright, thanks
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline
post #26 of 48 Old 01-22-2014, 12:16 AM
Dave02TJ
mine has a small purple wire. when that wire gets 12 volts it energizes the solenoid
Dave02TJ is offline
post #27 of 48 Old 01-22-2014, 12:17 AM
Dave02TJ
so its probably your bottom left, you have a different style than i do. is your bottom left purple?
Dave02TJ is offline
post #28 of 48 Old 01-22-2014, 12:19 AM Thread Starter
Bologna
So would that be the bottom left stud? It looks black but could be due to dirt and such.
Is there a negative wire on this?
All Stock
4.0 Inline 6
Manual Transmission
Bologna is offline
post #29 of 48 Old 01-22-2014, 12:19 AM
Dave02TJ
you are sure your battery is good right lol
Dave02TJ is offline
post #30 of 48 Old 01-22-2014, 12:21 AM
Dave02TJ
yeah that bottom left stud, that small wire goes through that plastic piece to it right?
Dave02TJ is offline
starter , tj , volt , wrangler
