Jeep Won't start - JeepForum.com
post #1 of 1 Old 07-28-2011, 07:03 AM Thread Starter
raiden169
Jeep Won't start
Hey all -
My jeep is refusing to start, and I was hoping someone here might have some advice for me. Its a 2004 Wrangler, 5-speed manual. Tried to start it last night. The car sounds like it is completely dead (doesn't turn over, no clicking like the starter is trying). I figured the battery was drained, so I had a friend try to jump it. Car started when the jumper cables were hooked up, engine would run when I was giving it gas, but then would immediately die if I took my foot off the gas peddle (won't idle). Had a AAA tow truck come out, and he hooked up a second set of jumper cables running from the battery to the frame of the jeep, at which point it started up and kept running without any problems. Took all of the cables off and was able to drive it home. Parked the car, turned it off, and it immediately went dead again. The tow truck driver said he thought it was an issue with the ground connection between the alternator and the battery.
Basically I was just wondering if anyone could confirm/suggest a few other possibilities before I start pulling wires off and trying to replace them. One additional piece of information, I looked at the starter motor and solenoid this morning, and both are completely covered in rust. I'm planning on replacing the starter at some point, but I'm not sure if it would be related the issue I'm currently experiencing (as I don't see why it would start with a jump and then immediately die).
Any advice you guys have would be great. Thanks
raiden169 is offline
battery cable , start problems , starter issue
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 10:36 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
Wipers start when I start the jeep Rock & Roll TJ Wrangler Technical Forum 3 09-07-2005 10:12 PM
Time to start thinking of getting rid of the Jeep...need help pricing out my Jeep... ///M Coupe YJ Wrangler Technical Forum 14 01-06-2005 05:41 PM
