Jeep won't hold a charge - JeepForum.com
post #1 of 17 Old 06-16-2010, 07:04 AM Thread Starter
allysdad
My 2003 Jeep Wrangler won't hold a charge. Fairly new battery. I can start it while being charged, but if I take my foot off the accelerator it dies. I've been told that it probably isn't the alternator because there's no clicking when I try to start it without being charged. Any suggestions? I'm a somewhat clueless female who would rather not have it towed if I don't have to!
allysdad is offline
post #2 of 17 Old 06-16-2010, 07:10 AM
Sundowner
Have you taken the battery out and charged it yet? If you drained the battery down, the alternator probably won't be able to charge it back up. I'm not sure what a "click" noise has to do with an alternator, though...
Sundowner is offline
post #3 of 17 Old 06-16-2010, 07:17 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Auto parts places will check the battery and alternator free.
TheBoogieman is offline
post #4 of 17 Old 06-16-2010, 07:47 AM
dieselcrackel
2017 JK Wrangler
What does "fairly new" mean? If you can start it while on the charger or being jumped started from another vehicle then more then likely the battery is no good.
dieselcrackel is offline
post #5 of 17 Old 06-16-2010, 08:29 AM
loaderopp
get a digital voltage meter, check your battery voltage.(12 volts plus) Then start your jeep and check it again while running. (13 volts plus, most will put out about 13.5 to 14 )
Check your connections and cables
If your not getting over 13 volts while running (alt) is toasted.
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #6 of 17 Old 06-16-2010, 09:24 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Put the battery on a bench charger overnight. A battery that goes dead & then isn't completely recharged will just cause problems. No, an hour or two on a bench charger isn't enough and driving it around isn't going to completely recharge it either. And a dead or nearly dead battery will, absolutely, cause the engine to die at idle. The ignition needs +12v and so does the alternator to work.
If the battery is dead or nearly dead, you won't get 13 volts from the alternator. The type of alternator the TJ uses doesn't work when the battery is dead or nearly dead.
Jerry Bransford is online now
post #7 of 17 Old 06-16-2010, 09:39 AM
Sundowner
I think Jerry's answered this question about three times in the last week.
post #8 of 17 Old 06-16-2010, 09:42 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
And another 10 thousand in all the auto vs manual threads because the manual owners always think they can push start their rigs with a dead battery.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #9 of 17 Old 06-16-2010, 10:05 AM
gmaus
Also, just as many batteries go bad when it is hot out.
gmaus is offline
post #10 of 17 Old 06-16-2010, 10:15 AM
Sundowner
Batteries go bad for a lot of reasons.
The point of my statement was that I am starting to get an idea of exactly how often the same questions are asked over and over again. I, myself, have answered that same question more than once in the last few days. However, Jerry is an acknowledged master on the subject (as are others), and me...well, I'm just glad to be here.
Also, the point was that with even the most casual of searches, people can find answers without needing to start a new thread.
post #11 of 17 Old 06-16-2010, 10:18 AM
-ExDementia-
1991 XJ Cherokee
That clicking would be your starter not getting enough juice from the battery.
"The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to get the job done.'" - George Carlin
Click
for the elusive search button everyone talks about.
-ExDementia- is offline
post #12 of 17 Old 06-16-2010, 05:08 PM
mightydog78
my battery wasnt holding a charge and i got a new alternator only to find out my battery needed a good charge
but get them both tested if you can, the alternator is super easy to take out
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #13 of 17 Old 07-12-2012, 08:24 AM
aussieTJ-06
Yep i did the same thing just bought a new alternator and was gonna charge my yellow topper tmrw and run some tests but now after reading this apparently all i need is a good charge to let the alternator take over from there CHEERS GUYS! the battery cost me 400 bucks here! i wos worried ide have to get a new one
aussieTJ-06 is offline
post #14 of 17 Old 07-12-2012, 08:35 AM
brianmlove
400 for a batter wth kinda battery are you buying
brianmlove is offline
post #15 of 17 Old 07-12-2012, 08:37 AM
jamesrw30
I didn't have the problem of it dieing at idle, but I was having a problem with it not charging to proper voltage when running and it ended up being a computer and a burnt pin on a plug. I know this may be a long shot but it is worth keeping in mind maybe.
jamesrw30 is online now
How much should I charge a friend for jeep work? YJames90 YJ Wrangler Technical Forum 48 12-24-2009 07:01 PM
Will the plastic pieces that hold the soft top on hold a bike rack? Keesh TJ Wrangler Technical Forum 7 08-29-2009 08:37 PM
98TJ Wont Hold A Charge BeerJ TJ Wrangler Technical Forum 1 04-16-2009 08:02 AM
Jeep won't hold battery charge Billyjon1 TJ Wrangler Technical Forum 4 09-11-2008 09:49 AM
Battery won't hold a charge. Swampwalker3 YJ Wrangler Technical Forum 5 03-09-2007 05:29 PM
