jeep will offer jk axles set up for a tj
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
wheel and off road reported this month that mopar will be offer there popular jk axles with tj brackets. hopefully they will also change out the bearings to a 4.5 on 5 lug pattern. Any one have any more info on this?
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs |
#2 |
Sorry,no info. What they should do is a limited partnership with ford and make some 8.8 setups for TJs.
Hold onto something... Quick!!! |
#3 |
#4 |
What's involved in converting a Ford 8.8 axle for uise on a TJ?
Rick, |
#5 |
It's never been done. Don't even bother trying to SEARCH for it.
-Ross 1998 Subaru Forester DD 2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy 1987 Coleman Columbia 3/4 ton+ tow rig wanted! |
#7 |
Come on now. You know you have a picture of an 8.8 on the ceiling of your bedroom.
#8 |
I presume you mean those high-pinion D44s from the new rubi?
#9 | |
Thicker tubes, higher spline count, high pinion fronts, "HD" stronger housings, they're much stronger than TJ D44s. If Jeep offers these axles at a price close to what they're asking for 2 JK D44s, I'd buy a set! Sell my TJ D44 and D30 and recoupe most of the cost. Hopefully if they do offer this, they put 5x5.5 pattern on it, (I'd even settle for 5x4.5).
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#10 | |
Brake Wizard
That's like telling someone to set up and build D-35's with bigger tubes.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#11 |
Brakes aren't included on those are they?
Colorado Jeep Club member #87 |
#12 |
It's got disc brakes on the JK 44
Other Vehicles: 07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs 08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers |
#13 | |
Under Construction
The bolt in for JK versions come complete from rotor to rotor, front and rear, but without steering linkage I think
#14 |
Brake Wizard
Trust me, I'm well familiar with the concept and even help develop some nice stuff for the 8.8. I just don't see enough value to base any kind of a modification venture on.
#15 |
Hey guys this is about the JK 44 axle NOT the 8.8...back on topic
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
