Jeep Will Not Start - JeepForum.com
post #1 of 11 Old 08-28-2012, 05:08 PM Thread Starter
jaymassey38
Jeep Will Not Start
I turn the key and dash lights work as usual but no click and no starter engagement. It started doing this a bit yesterday. I would turn the key to the start position and it would hesitate for a sec. then work. Battery is good, cables are good. Any ideas?
jaymassey38 is offline
post #2 of 11 Old 08-28-2012, 05:14 PM
Cuder
You might have a broken ignition actuator pin. Here is a thread with a video showing how to look at it.
http://www.jeepforum.com/forum/f9/ig...epair-1184102/
My Build Thread:
Cuder is offline
post #3 of 11 Old 08-28-2012, 05:48 PM Thread Starter
jaymassey38
I will check it out. Thank you.
post #4 of 11 Old 08-28-2012, 05:52 PM
Jeeper69
Same thing happened to me...only it would be on and off...
Don't take it to the dealer if you get it to start...fix it yourself...they ripped me a new one-$1200 to fix the ignition problem!
Jeeper69 is offline
post #5 of 11 Old 08-28-2012, 06:30 PM Thread Starter
jaymassey38
Damn! I will definitely fix it my self. I push started and it worked. I jumped the solenoid and it started. Just no love from the key.
post #6 of 11 Old 08-28-2012, 06:42 PM
Cuder
Here is a pin that broke. Sometimes the broken piece will get wedged just right and it will turn the ignition switch enough to start it, then sometimes it might not ever let it start again. You can pull the ignition switch off and see the end of this pin. You have to use a tamper proof torx bit to remove the ignition switch, I don't remember the size.
Some auto parts stores carry the part, I got one off a Cherokee at a wrecking yard for $5.
My Build Thread:
Cuder is offline
post #7 of 11 Old 08-28-2012, 06:57 PM Thread Starter
jaymassey38
Cool. I will check it out tomorrow. Have to go get the torx bit first. I appreciate the help.
post #8 of 11 Old 08-29-2012, 02:38 PM
Jeeper69
Cuder I should've done what you did...
Jeeper69 is offline
post #9 of 11 Old 08-31-2012, 12:36 PM Thread Starter
jaymassey38
Well, I got the part, but, Autozone sent me the wrong tool. They sent me a regular torx bit instead of the security bits I ordered. Oh well. One of the down falls for living in the country. Can't just run up to the store.
post #10 of 11 Old 08-31-2012, 06:09 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Try taking a small screwdriver or something like it & break out the pin in the center of the security bolts. Then you can use the standard T-10 torx bit.
Rubi4MyMrs is offline
post #11 of 11 Old 09-02-2012, 01:56 PM Thread Starter
jaymassey38
Good idea, but, I finally got the correct bit. She is fixed. Thank you all for your help. Funny, It took me four days to get the part and right tool and only 15 min to complete the swap.
ignition switch , starter
Jeep Wouldn't Start, Then Started, Now Won't Start - No Error Codes? drb TJ Wrangler Technical Forum 3 08-26-2011 12:50 AM
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 10:36 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
Wipers start when I start the jeep Rock & Roll TJ Wrangler Technical Forum 3 09-07-2005 10:12 PM
