Jeep Waranty - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Jeep Waranty
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 12-31-2003, 09:19 AM   #1
smott
Jeep Waranty
When installing a suspension lift (2-3 inches max), does this void the jeep powertrain waranty? I just purchaced a 2004 wrangle sport and after I joined this forum, I all of a sudden wanted to start customizing it. Has anyone had to deal with jeep for waranty work after they installed a lift?
smott is offline   Reply With Quote
Unread 12-31-2003, 09:32 AM   #2
StealthTJ
They won't warranty anything that you've replaced (springs, shocks, whatever), obviously, and they could deny coverage on anything else that the lift could contribute to, such as, but not limited to, the driveshafts u-joints, xfer case, diffs, etc.
Fred
[b]Base[/b] - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
[b]Suspension[/b]- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
[b]Misc[/b] - Tera 2wd lo.
[b]Tires[/b] - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
[b]Recovery[/b] - Warn XD9000i
StealthTJ is offline   Reply With Quote
Unread 12-31-2003, 09:34 AM   #3
TJx2
No, it will not void the warrenty. Although many dealers will lie to you and try to weasle out of it.
They obviously do not warrenty the aftermarket equipment that is installed, and they can refuse warrently if the mod actually caused the failure.
Other than that, it should be fine.
I have mine lifted and have had a ridiculous amount of warrenty work done to it and items replaced. Starters, driveshafts, transmission mounts, cracked plastic windows, an entire D35 rear end, radiators, manifold, et et et.
TJx2 is offline   Reply With Quote
Unread 12-31-2003, 09:38 AM   #4
StealthTJ
You have an exceptional dealer.
All the driveline stuff that you've had replaced, such as transmission mounts, driveshafts (especiall!), the D35 rear end, etc., couple easily not have been replaced, and more than likely would have held up in a appeal.
Fred
Unread 12-31-2003, 10:00 AM   #5
Scootr
Most stealerships round here tell me that if I lift her then it'll void my warranty.Of course I could fight this if I did the lift and the part that needed replaced has nothing to do with the lift. I'm just leaving her at stock height for now,just don't feel like argueing with the morons up there.
[B]Lead, Follow or get outta the way![/B]
[B] 2007 JK "X" 2dr [COLOR="DarkGreen"]Jeep Green[/COLOR],auto, 4.10's, 6 disc Infinity system with sub, 32's w/Pro Comp Xtreme Alloy Series 8179 wheels, Smittybilt SRC side bars,Sirius 1 unit, Magellan Maestro 3100 GPS . Former Jeeps...02 and 05 TJ Sports
[COLOR="Red"]SEMPER FI ![/COLOR]
[/B]
Scootr is offline   Reply With Quote
Unread 12-31-2003, 10:05 AM   #6
Jim Shanks
Ah, heck just go ahead and lift it. Part of the Jeeping experience is fixing things after they break on you. Just starts getting expensive afterwhile.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Owner of IA4x4.com
Subscribe to CRAWL
Jim Shanks is offline   Reply With Quote
Unread 12-31-2003, 11:35 AM   #7
TJx2
Fred
No doubt.. won't argue with you there.
Jeep-Eagle of Dupage in Wheaton IL BTW.
Unread 12-31-2003, 06:36 PM   #8
04JeepTJ
2010 JK Wrangler
Some dealers will install the lift for you!
I would have a hard time thinking that if my dealer who if I paid to install the lift would turn around and not honor the warranty on the suspension for no good reason.
2010 Sahara
04JeepTJ is offline   Reply With Quote
