jeep want idle after jump start - JeepForum.com
post #1 of 5 Old 06-14-2007, 02:48 PM Thread Starter
emt8c
i have a 2000 jeep wrangler that has a after market alarm that I don't use. I still have the original battery in it. I have left my headlight on and when I received a jump now it will not idle any ideas
2000 green sahara tj
project
emt8c is offline
post #2 of 5 Old 06-14-2007, 03:00 PM
FLATFENDER54
FLATFENDER54's Avatar
it will reset itself as the computer learns again.........this is normal (that should be the problem anyway)
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #3 of 5 Old 06-14-2007, 03:05 PM
mdm
Farm Wheeler
When a battery is run down you shouldn't rely on the alternator to recharge it. Recharge the battery with a charger, that may help things.
mdm is offline
post #4 of 5 Old 06-14-2007, 03:13 PM
Jonny Jeep
Jonny Jeep's Avatar
If the battery is very flat it will not run after a jump start. You need to keep the revs high for a few minutes to get some charge into the battery before it will idle on it's own.. I've done this with a hand throttle before, if you don't have a hand throttle you need to keep your foot on the accelerator, and someone else can disconnect the jumper cables.
You might have a shorted cell in the battery. Get it tested and replaced if neccessary.
Jonny Jeep is offline
post #5 of 5 Old 06-14-2007, 03:35 PM
Crashnburn80
Crashnburn80's Avatar
Yes. After a jump your Jeep will not idle. Keep the revs up a little bit, have someone else disconnect the cables and go for a 5-10 minute drive on an open road. Your problem will be solved.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
97 2.5L will not idle right rpms jump up and down eaglesfan8105 TJ Wrangler Technical Forum 9 01-14-2009 08:30 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 05:46 PM
jump start trouble Ignis8825 TJ Wrangler Technical Forum 5 12-15-2007 11:46 AM
Why Cant I Jump Start My Tj YELRJEEPTJ TJ Wrangler Technical Forum 16 09-02-2006 12:37 AM
Why does my alarm go off while trying to jump start my YJ? Quikcash YJ Wrangler Technical Forum 3 07-05-2006 06:29 PM
