Jeep Vibration at 55 MPH - JeepForum.com
post #1 of 5 Old 04-15-2012, 01:31 AM Thread Starter
dvdwly
Well y'all I need some help.
I have a 2004 Rubicon here in Japan and I have a vibration at 55+ MPH in the seat. The vibe started after I changed the tires from worn out Maxis Bighorn's to Goodyear Silent Armor's. Since then I have had the tires balances 4 times by 3 different tire shops and the tires replaced by Goodyear (they don't have the silent armor size in Japan so now I have Wrangler ATS's). The vibration was still there.
So I thought the problem may be mechanical. Since then, I have replaced the rear driveshaft, which had a little axial play but not more then a 1/16", rear axle shafts, the passenger side shaft was bent about 0.01, and axle bearings only to jump on the highway and feel the vibration again at 55+ MPH. It didn't seem as bad but it is definitely still there.
My Jeep is not lifted and is mostly stock.
Any help would be most appreciated.
dvdwly is offline
post #2 of 5 Old 04-15-2012, 01:37 AM
cavscout187
is it in your butt or in the wheel would just be a bad u joint in the front axel
cavscout187 is offline
post #3 of 5 Old 04-15-2012, 01:50 AM Thread Starter
dvdwly
the butt
dvdwly is offline
post #4 of 5 Old 04-15-2012, 10:57 PM
cavscout187
i would say rear u joint on your drive shaft is bad if i had to guess thats what mine did changed it and it was a ton better
post #5 of 5 Old 04-16-2012, 05:00 AM
65thwrangler
Had my read uni joint replaced because of the same problem, drive like a jeep again
65thwrangler is offline
vibrations
Jeep Vibration after SYE+ CV !!!! TheOrffs TJ Wrangler Technical Forum 16 11-20-2011 03:58 PM
Jeep vibration jpin86 TJ Wrangler Technical Forum 39 07-08-2011 08:14 PM
Jeep Vibration fred8801 TJ Wrangler Technical Forum 3 10-09-2009 10:53 AM
Jeep Vibration Please help fred8801 TJ Wrangler Technical Forum 9 10-07-2009 11:39 AM
jeep vibration wrangleryjman YJ Wrangler Technical Forum 2 09-16-2007 06:57 AM
