Jeep vibration - JeepForum.com
post #1 of 40 Old 03-03-2011, 09:49 AM Thread Starter
jpin86
Jeep vibration
I bought a 2003 TJ that has a vibration that starts at 63 mph. The Jeep is stock, no lift, Rubicon wheels with 245/70/16 tires. I have tried 3 different sets of tires, rims aren't bent, steering is tight. Jeep goes down the road straight, doesn't pull, and tires are wearing evenly. It has 60,000 miles on it, 52,000 when I bought it.
It is not the death wobble, and is NOT caused by hitting bumps in the road. If I go faster, the vibration doesn't get any worse. If I hit bumps the vibration doesn't get any worse. As soon as slow to 60 mph it drives smooth and quiet, and I can hit bumps with no vibration or death wobble.
I can feel the vibration in the steering wheel, but the whole Jeep is vibrating. So I don't know if the vibration that I am feeling in the steering wheel is because of the whole Jeep vibrating. When the Jeep is vibrating I can let go of the steering wheel and it will go straight.
The Jeep doesn't look like it has ever been off road or abused. There are no scratches on any part of the under carriage (skid plate, oil pan, axle diffs, steering linkage, ect...) and all of the stock stickers are still on all the parts (shocks, steering stabilizer, axles, driveshaft’s, ect...)
So far I have tried 3 different sets of tires(geolander ats, general grabbers at's, and now have kumohs at's). I just installed a new steering stabilizer with no help.
So I am thinking something is the driveline...driveshaft maybe? It can get expensive throwing parts at a problem trying to fix it. Anyone have this problem?
jpin86 is offline
post #2 of 40 Old 03-03-2011, 09:57 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
remove the front driveshaft and see if the vibes go away. if so, problem found - bad u-joint and/or unbalanced. if that doesn't fix it...remove the rear driveshaft and go for a drive in 4wd (FWD)...same scenario.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 40 Old 03-03-2011, 10:00 AM
markus05
I had the same problem twice. The first time was unbalanced tires, the second my U-Joints were bad.
markus05 is offline
post #4 of 40 Old 06-12-2011, 12:08 PM Thread Starter
jpin86
I know its been a while since I started this thread. I removed the front driveshaft and my vibration is still there. I can't feel any play in the rear u joints. There is a little play in the transfercase tail shaft...bad bearing?
So I figured I would install a sye. I had settled on a JB Conversions super short sye, but it seams as if they are out of stock right now. Any other recommendations on a sye, or super short sye?
jpin86 is offline
post #5 of 40 Old 06-12-2011, 12:50 PM
biffgnar
biffgnar's Avatar
SYE and CV driveshaft and rear adjustable control arms on a stock, non lifted jeep does not seem like the fix to your problem to me. Did you try pulling rear driveshaft and drive in 4H? I bet if you do that your vibe will still be there. Sounds like either a wheel balance issue (suggest trying road force balancing) or a front end issue (e.g. trackbar, control arm, etc.). I'm afraid you're going to spend a decent chunk of money on that stuff for your rear driveline and its not going to fix your problem.
Romney in 2020!
biffgnar is offline
post #6 of 40 Old 06-12-2011, 03:47 PM Thread Starter
jpin86
I don't know how I am going to remove the rear driveshift without loosing the transfercase fluid. I have checked everything in the front end, and everything is tight. The u joints in the front axles have a little play, and I need to replace them. Like I stated before I am on my 3rd set of tires and the vibration is at the same speed. I haven't done a road force balance yet. I need to find a shop that does that.
This is my 3rd TJ and I haven't had a problem like this with any of them. I also own a 1979 fiberglass CJ5 with 10 inches of suspension lift and a built 401. I can drive down the road at 80 mph, with no vibration, pulling...hands off the wheel.
If I can't find the problem with my TJ, I guess I will be looking for my 4th TJ.
jpin86 is offline
post #7 of 40 Old 06-12-2011, 03:51 PM
97tjtom
i have the same problem, its the rear DS ujoints.
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #8 of 40 Old 06-12-2011, 03:52 PM
97tjtom
and the DS comes out without losing fluid. the tcase has its own seal rather than how it was witht the older design.
97tjtom is offline
post #9 of 40 Old 06-12-2011, 06:13 PM
hustler905
I had a similar problem with a rhythmic pulsing vibration felt through the steering wheel.
Things I tried to get rid of them included the usual tire balancing, unit bearing replacement, more carefully torquing the lug nuts on the wheels, control arm bushing replacement, driving with no front driveshaft and probably more things I can't think of right now. Nothing cured this vibe.
Enter the Savvy/Currie Ultimate Currectlync system: It's basically a Currectlync with a 4340 heat treated tie rod. It went on pretty easily and bolted on in place of the stock system, exactly as the instructions state. The vibe is now long gone, and it cruises smoothly on highways.
I'm not suggesting you need something like I bought, but don't rule out worn steering components. I don't understand the mechanism by which it made the vibes rhythmic, but they are definitely gone.
hustler905 is offline
post #10 of 40 Old 06-13-2011, 04:53 AM Thread Starter
jpin86
Thanks for all the suggestions. I guess I will look at the rear driveshaft next. I still may install a SYE. I have a couple of cv stlye drivshafts that I can have cut and rebalanced. I don't like the big harmonic balancer looking thing attached to the stock driveshaft anyway. And I'll have a SYE allready installed for when I do lift the Jeep. I won't be going big, just 4 inches and 33s and 4.10 gears.
jpin86 is offline
post #11 of 40 Old 06-13-2011, 07:20 AM Thread Starter
jpin86
sorry double post
jpin86 is offline
post #12 of 40 Old 06-17-2011, 07:48 PM Thread Starter
jpin86
I changed the rear driveshaft u joints, and vibration is still there.
jpin86 is offline
post #13 of 40 Old 06-17-2011, 08:17 PM
MayRoll
Vibrations at certain speeds are usually wheel/tire related. Get up to speed, come off the throttle. If the vibrations go away its driveline issues (DS or U-joint). If you still get the sensation its wheel or tire. Try rebalancing.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #14 of 40 Old 06-17-2011, 09:50 PM Thread Starter
jpin86
When I push the cluth in the vibes do not stop, only when I get under 60 mph. This is my 3rd set of tires and I just had them balanced and rotated. I am running Rubicon wheels, and the tire shop said they are running straight.
I might try putting the Jeep up on jack stands and running it to see if I can see what is vibrating. I just have to talk my wife into running it.
jpin86 is offline
post #15 of 40 Old 06-18-2011, 12:45 AM
Heath
2014 JK Wrangler
Unit bearings?
2013 JKU Rubicon
Heath is offline
Vibration on my jeep when i hit 60MPH mjleslie33 TJ Wrangler Technical Forum 4 02-16-2011 11:49 AM
Jeep Vibration fred8801 TJ Wrangler Technical Forum 3 10-09-2009 11:53 AM
Jeep Vibration Please help fred8801 TJ Wrangler Technical Forum 9 10-07-2009 12:39 PM
98 Jeep sahara Vibration after 60 mph fred8801 TJ Wrangler Technical Forum 1 10-01-2009 06:55 PM
jeep vibration wrangleryjman YJ Wrangler Technical Forum 2 09-16-2007 07:57 AM
