Jeep Unlimited Modification Questions - JeepForum.com
post #1 of 5 Old 06-27-2005, 10:41 AM Thread Starter
nedyahr
OK, I am new to Jeeps, hell, I am a ******* to all 4 X 4's. I bought an 04 Jeep Unlimited. It is the same as the day it was bought new. I have a few questions because I know nothing about all this. I want my Unlimited beefed up.
1. Any suggestions on what to use to put 33" tires on? Can I use the stock 15" x 8" rims?
2. Will bigger tires screw up the speedo?
3. If so, what else will be screwed up?
4. What kind of lift kit will I need and any suggestions?
5. Told you that I am a ******* when it comes to all this.
Thanks,
Donald.
nedyahr is offline
post #2 of 5 Old 06-27-2005, 10:43 AM
0IIII0
I am NOT trying to be a d!ck, but as a fellow newb, I have learned that many of your questions have been answered or at least addressed. USE THE SEARCH button and then ask more specific questions is a much better strategy.
0IIII0 is offline
post #3 of 5 Old 06-27-2005, 10:51 AM Thread Starter
nedyahr
So what you are saying is that i am a ******* to the forum as well as the jeep. Thanks for not being a dick. I will try that search thing.
nedyahr is offline
post #4 of 5 Old 06-27-2005, 10:53 AM
0IIII0
Check out this thread, you will see what I mean:
http://www.jeepforum.com/forum/f9/3-5-re-sf-lift-31s-172326/
0IIII0 is offline
post #5 of 5 Old 06-27-2005, 11:34 AM
35sUnlimited
35sUnlimited's Avatar
Check out my sig you can see what I 've done to get 33's on.
I do not disconnect when wheeling, I am sure it would rub if I did. Without disconnecting I do not rub. Most will recommend a bigger lift for 33's. I just don't need much articulation for the mud and sand I wheel in.
You will have to change the speedo gear. Do a search. It is very easy.
Also, I personally am not happy with the performance of stock ring and pinion(3.73 to 1) with 33's. Overdrive is way weak for me. I will regear to 4.56's before to long.
Prior to 3" front springs
http://i13.photobucket.com/albums/a2...n/AUT_6820.jpg
After 3" front springs 'cause I didn't like the sag.
http://i13.photobucket.com/albums/a2...n/AUT_6859.jpg
http://i13.photobucket.com/albums/a2...n/AUT_6860.jpg
04 LJ Pics:
Half top write-up:
Painted Ravines write-up:
35sUnlimited is offline
Jeep gas tank modification bearhunter YJ Wrangler Technical Forum 8 08-13-2008 04:37 PM
Rear axle modification questions LedZepFan TJ Wrangler Technical Forum 0 05-19-2006 05:11 PM
new jeep unlimited questions... Blinky TJ Wrangler Technical Forum 11 09-27-2005 06:09 AM
