Jeep Unlevel - JeepForum.com
post #1 of 7 Old 04-16-2007, 10:07 AM Thread Starter
lukera
lukera's Avatar
Jeep Unlevel
Anyone here know what would cause my jeep to be 3/4" higher on the passenger side than the drivers side?
it looked like it was sitting funny and sure enough the pass side is taller.
2000 TJ sport
2006 WK
lukera is offline
post #2 of 7 Old 04-16-2007, 02:11 PM
Steelz19
I had this problem after i installed my bb and it was due to a broken shock. Might want to look there.
2000 TJ with 32" BFG's on soft 8's, warn winch w/ custom bumper, 2" Fabtech BB.... more to come (hopefully)
Steelz19 is offline
post #3 of 7 Old 04-16-2007, 02:57 PM Thread Starter
lukera
lukera's Avatar
how do i check to see if i have a broken shock?
2000 TJ sport
2006 WK
lukera is offline
post #4 of 7 Old 04-16-2007, 03:32 PM
thejafe
thejafe's Avatar
I bet I have your answer --
With the RE 3.5" springs it's common for them to unseat themselves when you flex out. At full flex with the swaybar disco'd your spring will be basically be hanging there, with the only thing holding in place being the bump stops. You could literally move the spring up and down 2 inches.
Because of this, when your supsension comes back down to level height chances are that the spring will not be sitting correctly in the little notch on your axle. Take a look, if it looks like your spring is sitting on the second coil you should flex out with the swaybar disco'd, rotate the spring until the pigtail is sitting in that little notch, and you should be good.
If you find that indeed your spring isn't sitting properly because of the reason above, then you can get a spring retainer clip at the dealership for $12 (for a set of 2 clips and the bolts to hold them). These clips came stock on some '97/'98 TJ's.
Let me know if you need it and I'll post the part #'s.
thejafe is offline
post #5 of 7 Old 04-16-2007, 06:08 PM Thread Starter
lukera
lukera's Avatar
you got it bang on...my springs were sitting all cock-eyed in the perches.
is this the part you were reffering to?
5200 5917 - BRACKET, Spring, Coil Spring Retainer, Mounting
2000 TJ sport
2006 WK
lukera is offline
post #6 of 7 Old 04-16-2007, 09:14 PM
thejafe
thejafe's Avatar
Cool, glad I could help .
Yep, that's it. There is also a bolt that holds the spring retainer to the axle:
Part #: 6502468
thejafe is offline
post #7 of 7 Old 03-07-2010, 12:30 PM
TontoKowalski
Can you post some pics up? My jeep's crooked and I can't figure out why.
TontoKowalski is offline
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 09:22 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep rear sits unlevel aklsufan TJ Wrangler Technical Forum 6 06-25-2007 02:26 PM
Rough Country4"x install, unlevel rear chutta TJ Wrangler Technical Forum 3 04-27-2007 07:16 PM
Looks unlevel after BB and BL 0blcktj6 TJ Wrangler Technical Forum 10 12-18-2006 09:31 PM
