Jeep unlevel. - JeepForum.com
post #1 of 4 Old 01-30-2011, 10:09 PM Thread Starter
Ezalycasaid
Jeep unlevel.
What can I use to make sure my jeep is level. Everything ive looked at is either slanted or just made uneven on the jeep. I went off of the bottom of my fender flares and the front is a little lower then the back but, when I put a level on the top of the place the softop holds on onto on the side of the back of the jeep. Its leaning backward. When I put it on the frame itself in the midde of the jeep its leaning backwards. Is there anything I can go off of to know if my jeeps level? the fenders dont seem to work. Also is my jeep leaning back a little a major issue?
Old build 99 TJ 100wb on 35s and arbs.
New build D60s, 40s etc.
I void warranties.
Ezalycasaid is offline
post #2 of 4 Old 01-31-2011, 12:54 AM
shortydog33
Maybe try putting a level under the rocker panels, seems like the largest supposedly level surface on the body of the Jeep.
shortydog33 is online now
post #3 of 4 Old 01-31-2011, 01:46 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I don't know why you care but I'd put a level under the rockers on the sheet metal.The ground would have to be perfectly level too.It makes no difference if it's level or not.I raise the front of my Jeeps 3/4" higher to make them look more level.They still sit 1" higher in the rear(as measured by the tire/fender flare clearance).It works for me.
TheBoogieman is offline
post #4 of 4 Old 01-31-2011, 11:14 AM Thread Starter
I have a 6" long arm lift with 3 inches of spacer on my front bumpstop right now and the steering wasnt squirlly like it is now untill I put it on. It seems like all the weight is leaning back now. Just kinda seems like Ill be more prone to flip backwards when crawling larger obstacles.
I void warranties.
unlevel jeep mtxhooligan JK Wrangler Technical Forum 4 09-16-2010 08:39 PM
Jeep Unlevel lukera TJ Wrangler Technical Forum 6 03-07-2010 12:30 PM
Jeep rear sits unlevel aklsufan TJ Wrangler Technical Forum 6 06-25-2007 02:26 PM
Rough Country4"x install, unlevel rear chutta TJ Wrangler Technical Forum 3 04-27-2007 07:16 PM
Looks unlevel after BB and BL 0blcktj6 TJ Wrangler Technical Forum 10 12-18-2006 09:31 PM
