jeep trouble - JeepForum.com
post #1 of 7 Old 01-22-2007, 02:26 PM Thread Starter
jarabolos
jeep trouble
Hey on cold days and on rainy days my oil pressure gauge wont work and reads as zero and the check gauges light comes on...after letting the car heat up for a while a re-start will make this go away...should i be worried??
obviously something is up...but how do i fix it?
is it worth going to the dealership for them to fix...any help would be awesome thanks!
jarabolos is offline
post #2 of 7 Old 01-22-2007, 02:36 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Odds are, 99.9999%, that it's nothing more than a defective oil pressure sender. It's inexpensive to buy and easy to install. It's located next to the oil filter.
Jerry Bransford is offline
post #3 of 7 Old 01-22-2007, 02:37 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
very common, take dash apart and clean the wire connecters for the gauge cluster then reinstall using dielectric greese
RnEmOvr is offline
post #4 of 7 Old 01-22-2007, 02:43 PM
Jerry Bransford
Administrator
That is only needed when all the gauges go whacko. His problem is only related to his oil pressure guage that when it reads zero, like happens when the oil pressure sender goes bad, the Check Gauges light illuminates.
post #5 of 7 Old 01-22-2007, 02:46 PM
RnEmOvr
RnEmOvr's Avatar
i reread once i saw your first post and realized my mistake, so to the OP just ignor my comment
RnEmOvr is offline
post #6 of 7 Old 01-25-2007, 11:23 AM Thread Starter
jarabolos
Thanks so much for the advice...does anyone have a pic of the defective oil pressure sender??
or perhaps a part number for an '03 TJ SE??
Thanks again soo much
post #7 of 7 Old 01-26-2007, 11:54 AM Thread Starter
jarabolos
i cant believe how much you guys know!
awesome!!
Jeep starting trouble 93jeepREDSOX YJ Wrangler Technical Forum 8 03-20-2017 05:41 AM
JEEP trouble HELP!!!! 5502george TJ Wrangler Technical Forum 1 01-21-2010 08:51 AM
I'm in trouble, Jeep is to much fun!!!!! shehatesme22 YJ Wrangler Technical Forum 3 04-25-2005 03:56 PM
Jeep has trouble starting GLADIATORTJ TJ Wrangler Technical Forum 2 06-24-2004 12:04 PM
BIG TROUBLE with the little JEEP!! Dembones YJ Wrangler Technical Forum 5 03-06-2004 09:46 AM
