jeep trouble - JeepForum.com
post #1 of 6 Old 08-05-2010, 05:44 PM Thread Starter
bayridgejeep
jeep trouble
Jeep wrangler starts up and has a normal idle, about 30 to 45 seconds later the idle becomes irregular and then shuts down, when I restart the jeep it turns on then then shuts off right away. I had a new starter and a new crank position sensor installed last winter and the jeep was running great no problems until now. HELP!!!
bayridgejeep is offline
post #2 of 6 Old 08-05-2010, 05:55 PM
Sundowner
Without more details, it's hard to say...so fill your profile in or provide more information about your Jeep. Any codes showing? Check engine light?
Sundowner is offline
post #3 of 6 Old 08-07-2010, 01:58 PM Thread Starter
bayridgejeep
jeep trouble
4.0 V6 2001 Jeep Sahara 44088 miles. No codes showing, and no check engine light. I turn on the jeep and it idles normally and then shuts off the minute you apply pressure to the gas pedal, afterwards the jeep turns over then shuts off. I've been told that it could be the remote start alarm, the CPS or the fuel pump. I put gas in two days ago and drove home fine the next morning I start the jeep up again and all this starts happening.
post #4 of 6 Old 11-26-2013, 11:48 AM
4x4jeeps4life
I am looking to buy a 2004 jeep Cherokee Laredo 4.0 and the radiator hose blow up and the guy fixed it and now you have to smash the gas to start it and feather the gas to keep it started any insight?
4x4jeeps4life is offline
post #5 of 6 Old 11-26-2013, 04:20 PM
Trendsetter75
2010 JK Wrangler
I have the biggest Jeep trouble, Going Broke
2010 JKU (6-spd)
Trendsetter75 is offline
post #6 of 6 Old 11-26-2013, 04:23 PM
JBTJ
Souds like a fuel pressure problem for both of you.
JBTJ is offline
rough idle , shuts off , tj , wrangler
JEEP trouble HELP!!!! 5502george TJ Wrangler Technical Forum 1 01-21-2010 08:51 AM
jeep trouble jarabolos TJ Wrangler Technical Forum 6 01-26-2007 11:54 AM
I'm in trouble, Jeep is to much fun!!!!! shehatesme22 YJ Wrangler Technical Forum 3 04-25-2005 03:56 PM
Trouble Starting Jeep Snowman01TJ TJ Wrangler Technical Forum 2 09-18-2004 03:40 PM
BIG TROUBLE with the little JEEP!! Dembones YJ Wrangler Technical Forum 5 03-06-2004 09:46 AM
